I listened so far to burr brown, muses and maxim ...... and all the chips are different to ALPS blue .... this is the volume control in my normal PreAmp. And the chips are not better ..... from my perception.
Yes that is possible - preference is very personal.
I went away from mechanical contraptions to control level a long time ago. Bad tracking, noise, and everytime you change the setting it's a different contact quality. I prefer the perfect tracking, repeatable, everytime-the-same and very high transparency of the CS3310/3318 and the TI PGA's, which are roughly comparable.
My preference.
Jan
My preference.
Jan
Still a question of taste .... ????
Yes, partly for sure. There are some objectively measurable advantages for solid state level control in terms of cleanliness, channel tracking and such, but if, what sometimes is called a 'clinical sound' is not your cup of tea you'd be daft to use them.
Edit: I have no experience with the Muses chip. I don't know whether it is a re-branded CS33xx or PGA or an independent development (unlikely but possible). Never listed to it or measured it.
jan
I don't like clinical sound .....
I need to tip with my feets 🙂
Tapping of feets comes from the music not from the equipment. I also tap my feet with my favorite music on the kitchen radio ;-)
.... I think, you must have a good kitchen radio ;-)
I heard good music from very expensive kits and my feet didn't like to tap 🙂
I plan to swap my ALPS blue by an Muses Solution. I'm curious about it 🙂
Muses 72320 kit from Japan
I purchased two 72320 kits with the MUSES01 opamps when I was in Tokyo two months ago intended to use them for separate L and R channels in my tube preamp. After assembly, I have to say this is possibly the best pot I ever had in this preamp - Blue Alps, DACT and Khozmo. The highs are crispy clear, the mid and low are with rich density, violin and vocals are singing in front of me. One can easily tune the sound by using different type of resistors on the output 33R. However, I have a problem.
Both pots work fine but one of them is generating a small "pop" from time to time. The sound is louder when volume increases. I swapped the opamps and there is no difference.
Can anyone tell me where to look at for this problem?
One more question. The kit uses + - 15V power supply and there is a 317 like regulator on the +ve rail to generate a +5V supply. There is a jumper for users to provide a separate +5V to the kit. Does anyone try it? How does it sound?
The "pop" sounds like it could be DC getting through to the 72320.
Are you using coupling caps at the inputs and outputs of the 72320?
There are 22uF bipolar coupling caps at both of the L and R channel input but no coupling caps at output. I've just soldered a 1uF bipolar at the output but the pops are still there but significantly smaller. Yet, my concern is one of the pots do not have this pop while the other has. Where to look at the possible fault?
I would put caps at the outputs as well. Otherwise, DC can go back into the MUSES from the amplifier you're using after it if it's not AC coupled.
Try something larger than 1uF and see if it helps.
I guess you tried swapping sides with the volume boards to see if the "pop" is isolated to one board or one side of the amplifier?
The rotary encoder sits too close to the 72320. I soldered the rotary encoder again leaving some margins between it and the IC, problem solved.
SunSun22,
Do you believe the inputs serie caps could be swaped by an input trafo à la Lundhal for instance ?
I don't know but the result is so good (or I should say great) that what is the benefit in adding a transformer?
I have a pair of LL1674 and a pair of LL1636 sitting in my drawer. Are they good for trying?
Datasheet doesn't tell us the thdn so I think this stuff is not so trustable.
I only want to repeat again:
For the MUSES we have received impressive specs figures from Stereophile, spiri (2x) and johncurtis.
The MUSES was auditioned from John Atkinson (Stereophile), spiri, Stefanoo, johncurtis and shoom.
Some of these people compared it in auditioning tests with best linear (resistor based) attenuators like DACT, Goldpoint and ELNA - the MUSES was always the winner.
Therefore: this chip is totally trustable! I wonder why you value it only for its specs....
- Analog Line Level
- MUSES 72320 electronic volume
