If you need 100, we can talk ;-)I am sorry about that. I used quite a few.
Jan
So if you can make and sell 100 units, you might be able to pull it off?
What would be the price?
I do not understand the formula. Input impedance is also a consideration.
Do you consider this a true balanced ("symmetrisch erdfrei") input - no.
I've had the paradise assembled but unused for 10 years, while I did several intercontinental moves. I'm ready to complete it now, however in the past 10 years we've had some changes to the family which makes shelf real estate a rare commodity. I previously used this big honking Italian boxes, but I just don't have the space for them anymore (amp, preamp, phono stage, record player... family says no!)...
What would be the smallest form factor you guys have seen in which to successfully box up the MPP? Especially given the sensitivity to RF etc.
This is what came out of the shoebox…. Obvious candidates are the banks of capacitors which a salvaged from an old project. But even after that, how to use real estate efficiently…
First off, check that trim pot...
You need ventilation for the main boards, the psu can be shoved anywhere.
@Joachim Gerhard
Hello Joachim, when I remember correctly, you mentioned a while ago that you had in mind to attempt building a pre-pre for an optical cartridge.
Did you succeed in any way and if so, could you reveal some of the results ?
Hans
Hans
