The idea with the power supply is that i do not use a plus-minus supply but only one voltage. Still this stage is mostly DC coupled.
I have not tried it but it could work on the Paradise.
To try that you have to cut the earth trace from Frans Shunt PSU.
I found that the sound improved when there is no earth connection from the PSU.
It is then floating.
I also have another good news. Hesener will make a small PCB for the Calvin buffer that goes into the Paradise. So step by step we are improving the Paradise.
Good news indeed JG.The idea with the power supply is that i do not use a plus-minus supply but only one voltage. Still this stage is mostly DC coupled.
All, when you cut that trace it is at your own risk. As i said, i did not try this on the Paradise.
And I will not give any guaranties on the usages of the two shunt PSU's (plus and minus) in series with no ground connection.
![hypno2 :hypno2: :hypno2:](https://files.diyaudio.com/forums/images/smilies/hypno2.gif)
How much distortion is audible :
Euphonic Distortion: Naughty but Nice? Page 2 | Stereophile.com
Here are some pictures of the presentation at Bauer Audio.
You see Stig Björge, Jonathan Carr, Martina Schöner, Willibald Bauer and me.
The speakers are prototypes.
Pictures of the Etna soon.
"Top Gear" fans will want to know if that's the "real" Stig
something different :
http://www.intersil.com/content/dam/Intersil/documents/an10/an1092.pdf
