The choice of transistors also shows in the frequency response of the pre-pre.
With the bigger Zetex -3dB is around 2MHz, with BC327/337 it goes to over 5MHz.
How do you call that C ?
Cob, Cis ?
Cob, Cis ?
Mr marsh, you're right about the distortion mechanism, but with mc, signals being so low that you only work at a ver narrow part of the transfer-curve, distortion will be so low that it's unmeasurable from the circuit, swamped by the performance of the cartridge. in simulation and in practice, this is the best circuit I/we have ever had.
A curious question. What RIAA-stage are you using after this Pre-Pre or have you built a complete RIAA based on this Pre-Pre as the first stage?
(( Per
(( Per
I once listened to the Audio Research phono-stage with numerous different curves. I was fun the hear how everything change, tempo background focus ect ect. maybe theres no such thing as other curves than RIAA but as an academic exercise it was quite intriguing
We need a high quality tone control and a mono sum rumble filter i think.
Of cause we also need a bypass switch and it needs an expert to adjust the EQ.
I have a Cello Palette. It makes bad recordings sound good but i do not use it any more.
It is just so huge and the many cables when you have it close to the listening seat.
Also it is quite noisy.
Maybe a Quad tild control is a good compromise.
I Mono times before 1957 there where numerous curves.
Also on some Deutsche Grammophon Stereos they used 50uSec instead of 75uSec.
Joachim, would it be possible for you to post a curve trace of Exicon and/or Toshiba Lfets? It needs to be Vgs vs Id to very low currents and have logarithmic scales.
We need this because we can use it to make accurate Lfet models in the crossover region.
If the VDMOS simulation model accurately models subthreshold conduction for Lfets, then we will have very accurate models.
Toshiba Lfets?
(Toshiba only manufactures Vertical MOSFETs, GDS pins instead of GSD)
The best would be the 2SK1056/J162, because Cordell already has SPICE models for those. If I can see the low-current Vgs behavior, I can just add in the subthreshold parameter and ideally they should be accurate in the crossover region, which AFAIK is the last major complaint of Lfet models.
Any other popular Lfet you can add in will help greatly in getting the ball rolling to get all these devices modeled properly.
