Mpl
Joined 2006
It is an amazing rig anyway......
Now I have a real question for you...
I am modifying a big speaker that uses four big woofers each 4ohm nominal impedance.
I need resulting impedance to be 4ohm..... what would be the best wiring:
Block A (Two in series to get 8ohm)
Block B (Two in parallel to get 2ohm)
1st option:
Block A in parallel with Block A to get 4ohm
2nd option:
Block B in series with Block B to get 4 ohm.
Hope you do not mind to share your knowledge regarding these secrets :)
Best
Ricardo
I am modifying a big speaker that uses four big woofers each 4ohm nominal impedance. I need resulting impedance to be 4ohm..... what would be the best wiring
Just to clarify, there is actually no difference electrically between your two options - you could use either one, and obtain the same results, assuming the four drivers are identical. The second option is in effect just the first option, but with the mid points of each A block connected together. Because the system is balanced the voltages at the mid points of each A block are the same, and no current would flow from one block to the other anyway. I prefer the configuration I posted simply because it has the most straight-forward wiring.
Joined 2006
I have been working as a professional loudspeaker designer and am proud of my work.
This one (AL THREE) is special because I designed the enclosure using Solidworks and became really good at it. Stenheim Alumine Three Loudspeaker - The Absolute Sound
I had to design several waveguides for the tweeter in order to obtain a better alignment and improve dispersion.
I had the help of hornresp for that also.
I did 14 versions of the filter until I got it where I wanted.
Finally decided to use two different woofers in the same bass reflex enclosure to get the bass to be brilliant.
...bass to be brilliant? Sorry, to spoil the party, but it is room modes that fool with even the best laid woofer alignment plans in conventional integrated (sub-)woofer-mid-tweeter systems. Double Bass Arrays, nearfield subwoofer placement or carefully tailored multi subs are the way to go. T.I.N.A.
Joined 2006
Maybe I was not very clear.... I needed to increase the upper bass nitidity so:
The Mid driver is a 5 inch device so it can not handle easily very low frequencies and is cut at 300Hz.
At the same time the Bottom Woofer (built with a soft surround) needs to be cut at a relatively low frequency (145Hz) in order to avoid colorations in the low mid region.
To cover the low mid region up to 300Hz, I decided to use a "faster" Top woofer (built with a stiff surround) that complies with the design.
The close technical relationship between the two Bass drivers enables me to use them in the same laminar bass reflex enclosure tuned to 40Hz.
