Most guitar cabs designed poorly?
@cbdb
That will work for sure.
But it is limited to only provide you with the proper sound - not necessary the rest of the band or the audience.
By this I imply that no PA is used.
It can also be a little bit difficult to tilt the speaker if you are using a seperate top (non-combo).
Cheers, Martin
