THANKS alot Tim, that did the trick !Hi,
Try the USB (UAC2) audio fix listed under PLAYER FIXES at moodeaudio.org. Its a workaround for bugs in Linux USB driver that may work for u.
Regards,
Tim
You can add SMSL M8 as supported DAC with UAC2 fix.
All is working fine 44.1, 48, 88.2, 96, 176.4, 192... even playing dsf file with DOP !
Hi, Tim
Clearing the cache doesn't help. If I choose the I2S audio device "Suptronics X400" menu Customize disappears. If you switch to another device with PCM5122, the menu appears. I tested on Win7x64/IE11
Regards, Serg
I even tried the browser TV Samsung, so that the cache has nothing to do with that.
Hi Phil,
Firefox has been problematic... Thanks for the Radio Caroline update. It will be in 2.6 🙂
Some items planned for 2.6 are:
(1) Access Point (AP) mode
Regards,
Tim
Finally, i don't have to install HostAPd manually. And dhcp server ?
Will you add Realtek 8188 firmware?
The realtek is working without adding additional firmware. One of my players has realtek wifi.
Btw, did you, guys, notice the release of the Raspberry Pi 3b today? 64bit, 1.2GHz quad core 🙂
Marek
(via Tapatalk)
Marek
(via Tapatalk)
Glad to hear that worked 🙂 The Linux USB guy has already made numerous fixes to the driver and at some it will appear in mainline kernel. Then workaround won't b needed anymore.
I'll add DAC to device database for 2.6, thanks.
Regards,
Tim
Marek
(via Tapatalk)
Yes, same $ as Pi2 with onboard wifi and bluetooth 4.1...
As for the 1.2GHz.....the Pi 2 already runs Moode without utilising anywhere near it's capabilities....@5-7% cpu during most playback
Would rather have more ram for ram-play or better clocking..🙂
Hi thanks for this nice project.
I have a request regarding moode audio.
I am using another pi with a tvheadend server Overview - Tvheadend this allows me to have access to radio channels via digital broadcasting and i can stream them to moode audio via tvheadend. However when i am doing this i can only hear hissing sounds. I wonder if the mpeg ts audio codec is enabled on moode audio. I have recorded a small file for you to try and see if you could solve the problem Free - Envoyez vos documents
Thank you Taiebot
Thank you Taiebot
True. I'm using PiZero's and they also barely go more than 10-15%. Even with hi res files. Anyway, with all these new boards it looks like a nice battle with benefits for the customers. I'm getting my Pi3 tomorrow so will see how it works (also with MoOde) 🙂
Marek
(via Tapatalk)
Marek
(via Tapatalk)
Thank you Taiebot
I think codec for mpeg-ts (transport stream) is in the lib that MPD uses but there is no support for it in MPD itself that I am aware of.
Regards,
Tim
I have a MT7601U wifi dongle. I have downloaded the firmware to /lib/firmware, i see that it is loaded (lsmod) and i see the wifi (iwconfig).
I tried to add SSID/password (the router does mac address filtering only) to the mpd client but the change is not saved. I also have static IP in mpd client.
What else should i do to have a wifi?
Thanks!
Thanks!
Thanks!
In my case (one of my players has MT7601U), after the firmware was downloaded by
I've just followed these steps and all was working after the rebootsudo wget https://github.com/porjo/mt7601/raw/master/src/mcu/bin/MT7601.bin -O /lib/firmware/mt7601u.bin
https://volumio.org/forum/realtek-usb-wifi-not-connecting-boot-t354.html
Marek
Marek
Thanks, I will try that!
Just didn't know which file to modify...
Issue with library panel, i have [library loading] message forever ......
I use pc as client with ff / chromium moode 2.5 is installed and i updated the distro with [apt-get dist-upgrade --fix-missing] without modifying any default config files
Browse panel, playing panel are working.
mpc listall list 52K files
mpc status list current playing file.
Library panel stay empty 🙁
issue: library loading forever
Rpi2 with Moode 2.5 + wifi + NAS
I did an update of the system using [apt-get dist-upgrade --fix-missing].
I added some folder from my nas somes do not contain only music files.
mpc update was ok
mpc listall give 52K files
Browse/Playback are working, but Library panel only show [library loading] forever 🙁
Does it exist a way to rebuild info and delete caches for the library ?
mpc update was ok
do your config (ip address, gateway, netmask) in /etc/network/interfaces
like:
allow-hotplug wlan0
auto wlan0
iface wlan0 inet static
address MYIP
netmask MYNETMASK
gateway MYGATEWAY
wpa-conf /etc/wpa_supplicant/wpa_supplicant.conf
and ssid and password in /etc/wpa_supplicant/wpa_supplicant.conf
Also, looks like adding ssid_scan=1 between ssid and psk lines helps, so:
network={
ssid="yourssid"
ssid_scan=1
psk="yourpassword"
Also, I've noticed, that my network provider's DNS wasn't working correctly (couldn't connect to the external servers), so I've modified the /etc/resolv.conf by replacing the local DNS with Google's one: 8.8.8.8
Marek
Hi friends,
concentrating on pure music experience one can have a look at this:
wtfplay-project.org
probably not designed to match with comfort-demands, it promises very good sound quality. But it will not fit on rasPi :-(
Maybe Tim can get some new ideas out of this, who knows ...
Luki
wtfplay-project.org
Luki
apt-get upgrade or list-upgrade will cause breakage.
Regards,
Tim
So the way to fix is to restart from blank sdcard 🙁Hi,
Regards,
Tim
Hi, Tim
I found the Customize menu disappears if I choose I2S audio device "Suptronics X400".
If I select another device menu appears.
Regards, Serg
Hi Tim, I'm having exactly the same issue here too, I've just upgraded my existing system to 2.5, that’s using an Iqaudio amp+ and I'm experiencing no problems at all
Just built up a friends X400 using 2.5 and cannot select the customize menu at all - tried from Firefox & explorer on XP, Firefox on Linux and chrome on Android and all the same, even when I try to increase the volume beyond 20% and get the warning pop up asking if I want to increase the limit, it still does not go into customization menu - everything else works as expected.
Rob.
- PC Based
- Moode Audio Player for Raspberry Pi
