Hi I am facing problem while creating image through automated image builder. Anyone else facing the same issue? Please find the attached screen capture for details.
Goutham
Try the download manually. Maybe the repos are busy or there is a problem connecting to them from your location.
Enter this url in a Web Browser (remove the space between http: and //)
http: //downloads.raspberrypi.org/raspbian_lite/images/raspbian_lite-2017-12-01/2017-11-29-raspbian-stretch-lite.zip
-Tim
ok, nobody seems available to help those who are not linux experts!i abandon the idea of trying moodeaudio ..
I was totally new to Linux, ssh etc until very recently. You certainly don't have to be an 'expert', and the Image Builder makes it very simple.
First, set up a Raspberry Pi running Raspbian that you can connect to via ssh.
There's plenty of info out there on how to do that, and when you've done it come back here for the next step. You can do it!
Cred for the Builder goes to @Koda59. From the use of server based config and helper file to the clever use of a Stepfile to allow the build to continue seamlessly across reboots. Its a terrific piece of work
-Tim
@Tim
@Koda59
Are you on a Windows PC or Apple ?I have a raspberry with Raspibian, i must understand how to connect it via ssh...
Windows PC
Windows PC
I use a Mac, so I may be of no further use to you. I think that on Windows you have to use something called Putty. Good luck!
Windows PC
To connect via ssh, install Putty or Kitty.
I opened and connected to raspberry
Cool! Now enter the commands that you will find at the bottom of the MoodeAudio webpage, under 'Support'.
ok.
"** Is target USB drive plugged in (y/n)? "
What it means this? It asked me to unplugged USB but i dnt understand this now
You need to plug an 8GB (or more) micro SD card in a USB adapter into the RPi on which to build the new image.
Ok..it s connected to usb but it gives me this error:
"** Error: Unable to find USB drive
** Image build cancelled
Perhaps unplug it and try again.
Again nothing!!
I don't know where things are going wrong. Did you restart the build from the beginning?
Perhaps someone else can help now?
Again nothing!!
Well,
Look at this post
To process an automated build, you need to have an USB Sd card adapter with a new SD Card in it.
Before launching the process, be sure that all USB Drives are unplugged on your RPI.
Then launch it.
Like in Tim's post :
** Are all USB storage devices unplugged (y/n)? Answer y (because nothing is plugged)
Later it will ask you to plug your USB SD Card adapter (with a new sd card in it), so plug it
** Plug in target USB drive for the new OS
And then answer y when it ask you if it is plugged
** Is the USB drive plugged in (y/n)? y
At this step, you will see something like this :
** USB drive detected on /dev/sda
Answer rest of questions and it will rock
If it fail, please copy/paste here the sequence
HI, all,
I'm using the mosbuild.sh to build moode. I get to the step where I am instructed to:
** Remove the USB drive and use it to boot a Raspberry Pi
** The build will automatically continue at STEP 2 after boot
I unplugged the Pi, removed the micro-SD card, left the USB drive in the pi and reconnected the power, but nothing happens. (Nothing appears on the connected monitor and the LED on the USB drive does not light up) Suggestions/instructions appreciated!
if i ll resolve this, could u tell me next steps?or after this all is done?
Once the USB drive is found the build will continue automatically, and after some time, it will be finished and you will be instructed to transfer the SD card to the RPi and boot it.
- PC Based
- Moode Audio Player for Raspberry Pi
