Just done this today, on a Windows laptop using putty.
And I do mean today; like most of the day (usual user error, as usual 🙁😕)
Got a bit mislead, misremembered actually, by the posting, "use the stock raspbian-stretch-lite image and start from Step 4", forgot the important bit about doing the wget and file unzip 🙄 .
All went swimmingly until Step 8 when lots of files did not exist 😱.
A lot of head scratching later, the light bulb went on 🙂.
So, here is a precis:
1) Burn the stock stretch-lite image to a sd card (I used a 4gb card). Create the ssh file in the boot partition.
2) Start the pi with the card insitu and do the password thing (from Step 3)
3) Use raspi-config to expand the card.
4) From Step 3 do the wget and unzip of rel-stretch.zip
5) go to Step 4 and continue.
I now have a working image, tomorrow I'll top and tail the extra bits and bobs.
If I get chance at the weekend I'll connect a rpi3 with a full Stretch image, keyboard and monitor and try the USB stick thing. Or maybe not.
Hope this helps.
Hope this helps.
Hi Tim !!!
i just was only registering here for saying soo much thanks you for your wonderful,wonderful MoodeAudio !!
I´ve tried 3.5 a long time ago and it was so wonderful !!->the best "sound" ´ve ever had/heard on a RPI3 with an ES9028Q2M !!
I´ve also come here by the Dietpi-forum; also a great distro as u surely know..
so at the minute i try to set up this 4.0 Beta on a RPI3..
I really don´t know why other here have problems in changing the download-options/"distribution-way" ;-)..:
they only have to wait a few days and then there were enough "finished" (with Moode 4) distros available..
Also i would recommend to still keep your "Paypal-Button" on your site to honor for your wonderful work !!
Again, in the name of all "audiophiles" ;-), so many thx for your wonderful MoodeAudio->unbelievable ;-)
so, another thing idea/would be, if i then have finished here the Basic 4 Beta 6 on a RPI3 (toi,toi,toi->German Phrase ;-) ) ,should i make an image of this and upload it to somewhere for user to download it directly and post the link here or at the dietpi-forum ?
i think this 10$ donation can still be taking place..i see no problem with it; its for your wonderful work and not just only for this MoodeAudio..
so, many many thx again for your wonderful MoodeAudio and greets for now ;-)
Been trying this on a pi zero
Was going OK until I finished Step 9 and did a reboot, now the pi appears to have disappeared off the network??? 🙁
PS anybody else messing with a PI zero you can burn an image then copy an empty ssh file and a wpa_supplicant.conf with the ssid and password into the boot partition.....that bit worked well lol
grumbleweed;5232110.....the receipe was easy to follow....[/QUOTE said:Unfortunately the first line in the recipe says it all........
"These instructions are written for Linux Enthusiasts"
I am not a Linux enthusiast, and for all I know, the rest of the text file could be Vogon poetry.
A pity.
Leaving a note just in case.... is there an upcoming i2s driver for ES9038Q2M ?.
I have been searching, though I think the chip is just too new so no joy yet.
I have tried all the usual options for moode but none of them fire up the 'lock' indicator and so no output.
Seems to be the same for a Voluminous user...
ES9038 I2S driver, DoP : DACs - Volumio
Hi Tim !!!
Maybe more than few days! Integrating moOde into another distro will take time and effort! Yes, there is a Donation button at moodeaudio.org 🙂
Your personally created image file contains 1000's of Copyrighted works including moOde Sources. Each are governed by various Licenses and distribution terms.
You are responsible for that file and for determining whether or not its permissible to redistribute it.
-Tim
sooo many thx for your quick answer !!!
this idea of making an image and upload was only a thought for/to help you..!! (i personally have no need to do it)..
i´m just at the minute "make" install the MPD-things..right now it just looks fine (toi,toi,toi) as said..
and i really cant believe that this "recipe" is without errors until now !!! (and is so straight-forward) ; it must have "cost" a lot of days to write and test/retest it !!!
so great, so many thx !! if nobody has something against it, i could post a "success !!" message here later (hopefully)(and maybe some remarks to help) ;-) !!
but again, so many thx "Tim" !! ;-)
okay, thx to you !! ;-)
(just here at step 7, before the reboot (can´t believe that this long recipe works till now ;-) ..unbelievable..))
Hi TimHi,
Yes, copy the .img file to a USB stick and then plug into a Linux box.
What version of Raspbian?
Can you post the error message returned after trying to run fdisk -l -o ... cmd?
-Tim
I'm using the very latest version of Rasbian Jesse (Version 8). When you run the fdisk command it simply says "fdisk: invalid option -- 'o' " .
When you run the man fdisk command it is clear that the -o option is not there so you would not be able to use a RPI running this distro to do steps 1 to 3.
What I did discover was that an RPI running the latest bacic stretch lite distro does in fact have the -o option available in the fdisk function.
I am going to follow first three steps of the recipe using an RPI2b running stretch lite and report how it goes.
Hi Tim, Build went well...Great instructions !
I am assuming that the final 'additional components' can be left out if I'm not likely to use them.... and can be added later, if I do need them, using that part of the build recipe...??
On a Pi 2/3 can the compile be sped up using the -j4 switch to maximise cores?
This may already be the case, I can’t get the Pi off my wife to try the build...
maybe someone with experience can write an Ansible Playbook for an automated build of moode and put in on Github?
Would be great!🙂
Would be great!🙂
Hi all,
I did step1 and 2 on a fresh Debian 9 install on an old Laptop. As i'm no linux guru i have choosen automatic install. With that the user that is created automatically seems to have root rights, so i did have to leave out the "sudo's" in Step 2.
The rest of the receipe is working like a charm. The build is ready now.
First try was with Allo Kali and a Piano 2.1 on a PI3, where i also compiled the image - but no chance to get sound out of it.
Then i put the SD card in a PI2 with a cheap PiFi-DAC - working great and the parametric equalizer does a great job in flaten the sound of my small fullrange speakers in the bathroom. Ridiculous.
I hope MoOde will be soon integrated in DietPi or LibreElec, but would be very happy if it will stay possible to create the MoOde only with following updates and versions by using the great recipe.
Is there a chance to use the advanced kernels of beta5 in beta6 ?
Thank you, Tim for all the effort you did to give us this system. Must have been a lot of work to build this error free long recipe. Everthing is working perfect.
I also will donate today.
-Josef
-Josef
Having built beta 6 there are no other options than standard kernel ??
Did I miss something or are the rt and LL kernels no longer available..??
That reminds me........😀
"Ah, H2SO4 Professor! Don't synthesize anything I wouldn't synthesize. Oh, and the reciprocal of pi to your good wife."
Songs from the History of Science: First and Second Law
YouTube
Unfortunately advanced kernels are missing. Tim stated these were made by someone else. I also hope these could be integrated anyhow.
@Tim: Do you think there's a way to ask the developer of the advanced kernels if these could be downloaded and be integrated ?
-Josef
-Josef
That is great work from Tim but that GPL story is a curse.
I do not like computer much and non-user friendly things about it but even less now. I'm not skilled enough for the way it is now. Way too complicated for me sadly, I'm left on the side of the road.
Thanks anyway Tim, for all you've done and the 3.8 I'm using "for ever"!
Hmmm.
I downloaded moOde 4 beta and then ?
Where is the recipe ?
I found in this forum, that the recipe is under sources and the name of the recipe is not recipe, but i have to klick on "moOde 4 beta 6 Build" to get the recipe.
Maybe it will be easier to put the direct link for the recipe on the moOde frontpage ?
Tim, why it is not possible to create an installation script, which is doing exactly the same, as the recipe ? The user has to start start the script (after reading GPL) instead of doing the recipe ?
Or after booting Pi with downloaded image there will be a possibilty to reach Pi with the webbrowser and start the installation script with one click (after reading GPL or whatever), if the user has to start it, because You are not allowed to distribute complete images.
Anyway Tim, thanks for Your great work and hope for the good future of moOde. 🙂
- PC Based
- Moode Audio Player for Raspberry Pi
