Monsoon planars
When tweeter is not flipped, thare is dip around crossover frequency and phase goes to hell.
I worked a little on midbass crossover, since its raining. Got second order working ok. This is how it looks with 150Hz high pass by simple active crossover and 300Hz low pass.
Just to bridge 15" woofer to the planar mids.
And the response of midbasses with planars
Total system response. Yes, there are room modes. Its a small room and no eq is used. Sounds ok. After some more painting I will test it downstairs in the main system.
Reactions: studiotech
i recently came across monsoon pc speakers, i think they are either mh500/700 its just the speakers with small din 4 connectors like old s-vhs connectors i presume when the connetors are cut off i would only need to connect 2 of the four wires to an amp to run them?
No, mh500 have one pair of wires for planar tweeter, one pair for small 3" junky fullrange. I have seen no crossover inside the satelite speakers. Must be inside the controller.
If you want to use planar and mid, you need to use four wires, or implement crossover, then from crossover you can run one pair of wires to the amp.
Crossover point is 1500Hz.
Too low in my opinion. But poor mid is much worse, so it does not matter after all.
I disassembled many of these and every one had a passive XO (cap+inductor). no pics of one, there are probably still some downstairs somewhere.
Pics of the rest:
dave
Reactions: Yaka
IIRC both the 2 way MH500 statelites anf the 700 panels had RCAs on the end of their cables. The controller had a multipin connector. Pictures?
dave
thats what i had assumed as well but to my untrained eye they look like svhs connectors
i just took a gamble on this thinking i could wire them up to a usb dac with hypex amp along with a old small m&k subwoofer i had in storage
so if i cut the wires which how do i work out which wires belong to the plana and fullrage? would i be ok combing each of the positive cables and negatives to go into the amp?
well i cut the connector off i got 1 red, 1 green, 1 black and 1 white. from trial and error red and green are planar not sure which one counts as black and red on my amp sockets and the little speaker is black and white. these speakers were an impulse buy for my pc but sound decent
If you decide to do something better with those, remove the monsoon logo, its just glued with hot glue. There is one screw under. This holds entire metal grill. However, they use sticky stuff all around, you need to use some force to remove it.
Then you are facing the drivers, each held in place by four screws.
Reactions: Yaka
