Monsoon planars
If you decide to do something better with those, remove the monsoon logo, its just glued with hot glue. There is one screw under. This holds entire metal grill. However, they use sticky stuff all around, you need to use some force to remove it.
Then you are facing the drivers, each held in place by four screws.
was wondering how to take it apart. but seeing as its working fine paired with a small old sub i had lying around that will do me fine
well new years eve, an i have just unearthed a minty MM-1000 set with working sub, only problem is the sub needs a stepdown power converter as i am in the uk, so i wont be using it. hooking the speakers up to a 50w dac/amp and sound sweet.
i may either sell the sub or at least try and upgrade it at some point
Just picked up a pair of MH-505 Satellites and matching sub. Satellites sound awesome... Does anyone know if there are better 3" drivers out there that can be easily swapped out? Does the swap involve re-designing a cross-over (I think beyond my ability).
Also, is there a $100-200 musical sub (powered or not) that might pair well with these, that crosses over at a higher frequency?
Thanks much!
David
The 3FExx wants a significantly bigger box than the Monsoon has. Not sure how it differs from the many MH-502 i had thru here, but the midrange is more like 2.5”.
It sounds like you want to start from screatch but use the eletrodynamic tweeter? Tou might have sensitivity issues with most 3” FRs. Aura NS3 (Dayton does them now) could use some HF help and is a bass champion. But it needs a biggish box.
dave
PM-9 shown in this mock-up. Needs tweeter and woofer....
(PM-9 is held together with screws, not rivets btw.)
I made this frankenspeaker which has been my desktop mini-monitor for several years - better than my wildest hopes
The base is a radioshack cast alu ported box with a replaced tangband long throw mid-woofer , minor crossover tweaks, the box and planar have great synergy. I did measure this way back but don't have the graphs at hand.
..dB
I found a set of MH-505 speakers (MH-500 but configured for 5.1, with 4 sats + 1 center) for sale at a local marketplace, minus the subwoofer/amp, for under $20 in mint condition.
Is it a good deal? Can I turn it into a 2.1 nearfield setup, with new enclosures for the sats (since the OG is ugly as sin)?
