I have designed a form-fit-function replacement output board for the DCX2496, an article on it has been published by AudioXpress (August issue). You may want to take a look at that.
Jan Didden
Edit: Just realised this thread is on the DEQ not the DCX. Sorry....
Jan Didden
Jan,
No problem. As I am also looking into possibilities to use the DCX with my Maggies, the information may still be of benefit to me and hopefully others.
Thanks for mentioning.
Haven't touch my deq2496 for a while as I was working on my harddisk media player (TVIX) with I2S to TDA1541 (yes, that setup sounds really good, if someone can tell me how to interface I2S with deq, I will be very happy...)
Anyway, last night, I tap the ak4393 direct out to a tamura 300:600 tranny, it sounds really good, only got one channel working so far...
But the PS, the 9V is really really important, it feeds the 7805 that provides all chips that uses 5V, this includes the dac of cause.
And the 9V doesn't seems to go thru any inductor to reduce noise, so should be a good idea to add a coil and more caps for that 9v. The 7805 gets really hot with means its drawing quite a bit of current.
The LM317 will take the 5V and output 2.5V, so should be for the dsp chips. I found that there is a ceramic directly at the LM327 output, a real no no for this type of regulator, so I took it out.
Instead of improving the supply to the 7805, you would be better of removing the 7805's from the board, and using outboard discrete regulators like jung, super-jung or similar boards. Selectronic sells a replacement regulator kit at an affordable price, or you can do your own.
Hans
Hans
Hans -
Do you have a cite to the Selectronic kit that you mentioned? Apparently my google skills are not up to snuff. TIA- Pat
Ouch, that regulator is expensive.
Providing seperate very low noise for each chip doesn't cost that much. Eg, some like the LT1027, LT1763 will probably do as good if not better.
sorry for my english
this tweak in french only
http://www.dcx2496.fr/
and
http://groups.yahoo.com/group/DCX2496/
english speak
and
english speak
So I drifted over to the Slim Devices website, and they are coming out with a new device http://www.slimdevices.com/pi_transporter.html called the transporter... which they claim uses the "Miracle DAC" - AK4396
ok, so, I have played with AKM dacs before, since my behringer has an AK4393... so i head over to AKM's website... and it looks like a really nice chip... and it looks like its pin-per-pin compatable with the 4393, 4394, and 4395!
but the best part, it needs NO output caps! none at all!!!
I am definately going to see about trying to find some of these IC's and try swapping out the DAC in my DEQ2496 and making a new, capacitor-less, LPF and see what happens 🙂
I've got a SRC2496, which supposedly uses the same 4393 DAC, and I was looking to do that DAC swap as well, or at least bumping up to the 4395. Have you found a source for small quantities of the AKM DACs? The only place I've found so far is DIP international in the UK, and their minimum quantity seems to be 50... 🙁
One thing to think about is that those filter caps *are* in your signal path, even though there's no DC blocking caps required. Obviously, it's easy enough to get high quality caps in there, but I was thinking of going passive with a transformer, say a Lundahl line-level or somesuch.
well, they are not really directly in the signal path dc blocking, just part of the filter... so some nice caps and you should be good to go... or you can just omit the filter entirely I guess...
I have not been able to source them in small quantities yet... working on it 🙂
densen2002 said:
densen2002, the file has gone. May I ask for a repost (or email)?
Thanks!
FLECOM said:[snip]but the best part, it needs NO output caps! none at all!!!
[snip]
Neither does the '93, if you use the balanced to se converter you showed and which is shown in the data sheet. Both the '93 and the '96 need coupling caps if used balanced (their outputs sit on 2.5V DC).
Jan Didden
FLECOM said:i was just wondering about output transformers, instead of the $200 dac output transformers that were linked to two pages ago couldent you use these sowter transformers and still get a balanced line out?
http://www.sowter.co.uk/specs/3603.htm
Here is what Sowter answered when asked about it:
Hello Alain
3603 would be ideal provided the output impedance of the DAC is 1000
ohms or less. The load should be as high as possible so your high
impedance amp will be ideal.
http://www.sowter.co.uk/acatalog/SOWTER_ISOLATOR_BALANCERS_2.html#a9
Best regards
Brian Sowter
SOWTER AUDIO TRANSFORMERS (E A Sowter Ltd)
This transformer will handle the balanced/unbalanced conversion as well. That must be a good candidate but I definitely don't have the knowledge to really recommend it😉
Jan Didden
according to the datasheet the 96 dosent need any dc blocking on the output at all...
It will need a cap if you use only one of the outputs from the chip e.g. the + OR the -, in singled ended fashion.
Dan
- Digital Line Level
- Modify Behringer DEQ2496?
