Mmini regulator (sample offering)
analog_sa said:
Many thanks to Coffin for graciously providing the sample boards.
May I join you?
Thanks, Coffin. 😎
Received my boards some days ago, good quality PCBs indeed.
Well, as I needed a little more 'flexibility', I used 2.2K trimmers, paralleled with 10K 0.6W film resistors, for R2 and R12.
1K 0.6W film for feedback.
This way I can easily adjust for the range I wanted to, that is, between +/-12V and +/-18V.
I used one of the holes of the unused caps, C7 and C17.
The adjustment works well, but if I had space I would use a series resistor with the trimmer. Because the adjustment is wider than what I needed.
Also, I'm using the 5.0V LM336, and a lower gain on the op-amp (OPA627BP).
For ZD1 and ZD2, I'm using 10V/1W zeners.
EDIT: I'm using Elna Silmic 100uF/25V output caps. Diodes are MUR1100.
Here it is.
I got a sample PCB a while ago,now I am building a Krell KSA 50 clone and I found a trafo I could use for a regulared PSU for the front end...
How much current can the Mini reg give at +- 40v,if I change D1,D2,D11,D12 for 3A types,kan it give say 1-1.5 Ampere?
with most opamps. 30 or 36 V is max.
The OPA445 max voltage is +- 45v,the opamp was recomenden in the mini reg´s webpage.
I was told that the drivers for KSA50 would need max 0.5A per chanel,thats 1A for the regaulator if I make R6/R16 so I get 1Ampere max,doesn´t I need any headroom,just incase they would have to deliver more current?What will happend if I make the regulator deliver more than 1A?
