Mini-Me phono preamp
You´re welcome.
It´s not a repost, since these were never posted before. Just the GB that ended some time ago 🙂
Just needed Koifarm´s & Flancfuster´s permission before posting them, so the thanks goes to the two contributers 🙂
I have made a new Mini-me PCB.
Just ordered 10 pieces.
This PCB you can(not needed) mount tubes and dip switch on solder side.
Then dip switch can changed at upper side of casing and the tubes stick out of the casing.
PCB has all the parts for a MM Mini-me except the transformer.
After PCB is tested, rest is available.
Did some soldering today. Test it tomorrow.
Had to drill 2mm holes for 3 biggest capacitors.
Further simple build.
