Midrange experiment with Auto sound panel deadener and high density acoustic felt..
One of the Master Jedi's of loudspeakers once proved that the measured response inside a cabinet is the same as the total power response on the outside of the cabinet. It may seem obvious in hindsight, but he proved it mathematically... I don't remember if it was S. Linkwitz, A.N. Thiele, S. Lipshitz, or someone else.
With all the stuffing and absorption in a modern cabinet, this really only applies below 100 Hz or so... Above that and the stuffing absorption takes over.
I recently used the mic-in-the-box technique to prove to myself that a wierd low frequency null was not a room mode, but was measurement related.
Perhaps this is what you mean Jim
"When a speaker driver is mounted in a box it radiates as much energy into the space in front of the cone as it does into the much smaller space behind the cone. What happens to the air borne energy inside? At long wavelengths it is common practice to store it in resonant structures to extend the steady-state low frequency response of the speaker. In general, the energy leads to very high sound pressures inside the box. A small amount of the energy is lost as heat in the stuffing material, some in the process of flexing the cabinet walls. Much of it reappears outside the box, because the thin cone presents a weak sound barrier. Just how much is difficult to measure, but it is a contributor to the frequency response. I am of the opinion that the effect is most notable in the low hundreds of Hz region, where stuffing materials are ineffective and the internal dimensions not small enough for the internal air volume to act as a pure compliance. Consequently, enclosures should be either very small (less than 1/16th of a wavelength) or extremely large, both of which are not very practical for different reasons."
Frontiers
Where does 1/16 wavelength come from?
Since my box is stuffed to the brim with high density felt, a much larger amount is lost as heat, to the point that the frequencies above 90hz are less loud in the box than outside the box at the same mic distance from the driver. You can also see here that the lowest half wavelength resonance makes it's appearance at 600hz. The box depth resonance is confused by a vertical brace parallel to the baffle.
The above picture represents only one pass through the felt interior(I'm using the shortest sweep, with the mic situated toward the back). Much of what escapes through the driver membrane actually has to make two passes through the felt interior, so the bump we see peaking at 2khz is probably much lower in amplitude by the time it gets back to the driver. Another thing that's creating that peak is the mic being situated exactly between the two sidewalls. The driver cone is also situated exactly between, so it's probably a pretty good representation of what the cone sees when the sound is reflected back
Another strange measurement from inside the cabinet. Look at how harmonics 2 through 8 completely differentiate themselves below 150hz vs outside..
