Mezmerize DCB1 Building Thread
That's a stepped attenuator.
All the components would need to be 0.1% or better.
The sums of components in the two balance halves would have to be 0.1% or better.
The resistances across the contacts would need to vary by an amount of less than that, that would cause more then 0.1% of mismatch in any of the sums of values.
It can be done, but it will need a lot of matching (=time)
Finally I did the hot-rod first stage and I'm very impressed, the bass are incredible, as well the sound stage are wider and deeper.
I'm using two 16 Ohm resistors in parallel, the DCB1 are now close to 200m to 210mA (The voltage across the resistor drops a bit) (The DCB1 is cold).
A photos of the "near to finish" Mezmerize:
Thanks Salas!
I guess 8 W of heat just "dissapears" on such a big metal bottom plate.
Its a sign that the (9)240's are making great thermal contact.
Measuring locally with a "temp gun" could reveal whats really happening
@Ram, why didn't you put the toroid together with the other stuff in one enclosure?
Jan
I don't think a (9)240 can be cold on the outside while they are burning on the inside at the same time.
Ram reported everything to be cool, so I assume his (9)240 are cool on the outside as well.
"A cool device is a good clue to good thermal conductance". I fully agree with that.
Jan
an example of a bad thermal conductor to a device with air between it and the heatsink.
remove all the bolts holding the CCS devices to the base plate. Lift them ever so slightly from touching the base plate.
Do you think the case will be cold and the devices burning hot on the inside?
It's an extreme example but it shows why a cool or cold heatsink cannot be used to determine whether a device has adequate cooling.
It's the device temperature (Tc) that matters.
What is the voltage drop across the CCS mosFET Drain to Source?
How low will that Vdrop go if mains is at minimum tolerance?
I'll measure tomorrow the voltage drop on the mosfets.
The voltage drop on the resistors:
http://www.diyaudio.com/forums/pass-labs/176723-mezmerize-dcb1-building-thread-12.html#post2433104
Now is down a bit 1.49V and 7,4 Ohm of measured resistance on both sides (The two 16 Ohm resistors in parallel), the offset remains the same.
I'll try with the variac down a 10% the mains for see (My regular AC is 230V).
