Mezmerize B1 Buffer Preamp
They should be sharing Id current and dissipation better equally when chosen more Idss balanced to pair.
P.S.
DCA tester only uses 3V VDS so expect little more IDSS and gfs when 10V tested as per Toshiba datasheets.
Hi.Milliput is an interesting idea! It prevents the chips and also helps cooling too? I was thinking wrapping multi wire thin copper around fets but 30C is not a problem IMHO.I do not know why people put smd coolers on them.(it sometimes reaches 38C here in Istanbul in summer and we should consider putting them in a box and it will be hotter than free air then)
I also ordered same pcbs from Aliexp and will try as soon as i get pcbs.Now i need a sot23 adapter to match them.(yours seems a good choice but it seems a bit expensive) Regards Umit
