The voltage is dropping very low. If you use a car battery, you MUST have a 10-15 amp fuse in the B+ line.
What was the original complaint with the amp (when it was installed in a vehicle)?
Have you checked the output transistors? You can probably check them without removing the clamps. You should not read anything near 0 ohms from the metal tabs of any output transistors to either of the two orange arrow points in the photo.
Thank you perry I believe the original complaint was no sound and the speaker sounded like it was snowy every once in a while not all the time
ill try the car battery and retest the ic I used the ground probe on the meter to the ground terminal on amp do you think that might have been the issue I tried the ground on the 3205 fet rails but when I tested the volts kept going down
Pins
11 - 9.53 v
12 - 9.53 v
The rails test from the ground terminal of the amp still OL no change
The Amps acrossed the +/- I have a reading of 12.12 volts and this is a optima battery yellow top and it maybe alittle low on charge due to storage over the winter however I usually charge it once a month during storage
11 - 9.53 v
12 - 9.53 v
17 ohms with amp powered up or not?
If the amp was on, that could be normal. There probably isn't a specific resistance that you'd read across the terminals with the amp on.
Did you try connecting a speaker and a signal source to it to see if it was making the sound that the owner complained about?
- General Interest
- Car Audio
- Memphis 16-1000d
