MarkAudio MAOP 11 single driver loudspeaker
Also interesting.
I like to built the Lhotse with these beauties.
Or EBS?
Depends what you're aiming to achieve; they have different alignments. The EBS is fairly self-explanatory & is aimed either at high output impedance amplifiers (for modest levels) and / or fairly near-boundary positioning -front wall or corners. Lhotse is a low-forced MLTL that's a bit more flexible in terms of positioning & amplifier load requirements. By design, it's got more output as-is.
Should internal bracing be sufficient?
The inner section is very narrow and I use 28mm solid side panels and 2x 18mm MDF baffle and back panel.
The inner dimensions and baffle wideness are according original design.
I don't want to disturb the standing wave.
