Marantz CD63 & CD67 mods list
Troubleshooting CD67
Hello all,
I'm fighting with my CD67 which became silent after unsuccessful try to feed separate +5V to DAC. :bawling:
I've connected the player to receiver using digital out and it is playing, so it's not completly dead :D I've connected 'scope and measured digital inputs to DAC and it seems to be ok, but the DAC output looks the same in stop and play modes (picture attached). :dead: I've noticed in service manual that DAC pin 13 (MLEN) has to be 0V and pin 14 (RSTN) has to be 5V. In my player it is vice versa i.e. MLEN is 4.94V and RSTN is 0.12V. :smash: Is this another error in service manual or this could be my source of problem?
If somebody could measure these values, that would help me a lot. MLEN can be measured at U151 in CD67 or U174 in CD63/53/43. RSTN can be measured at U152 in CD67 or U173 in CD63/53/43.
Re: Troubleshooting CD67
Hi Renatas,
It appears that 0V for MLEN is an error in the manual. I measured both RSTN and MLEN and they are both +5V in play and stop mode.
Your MLEN pin seems to be in order, but RSTN is held low somehow. Could it be a short to ground? The groundplane is running alongside the trace to U152. You can try lifting the pin, it should go high when it's unconnected, because it has an internal pull-up.
Ray.
poynton said:
Hi.
Ray , are you sure? I have heard that some CD Players have a tendency to spontaneous combustion !
Yeah, I noticed that some time ago, there was a lot of smoke hanging around this thread :clown:.
The size and type of capacitor after the regulator is a matter of some debate.
Some say that a large cap. does not allow the regulator to react fast enough.
Certainly some regulators do not like low ESR caps such as Oscons.
Also if the cap is large, a reverse diode must be used.
Andy
I agree, bigger is not always better. But an increase from 3300u to 4700u won't cause any problems. Indeed if the ESR goes too low, the regulator can become unstable. Most regulators can handle a big output cap very well these days. The reverse diode is a good point, it won't hurt to insert one from input to output, gy21.
Ray.
Ray.
Thanks Ray,
The raise of C805, C806 from 470u to 2200u also won't cause a problem? I saw that you did it in your cd67se mod list and also tnt does it so it should be fine I think.
I'm using Panasonic FC for all replacements, so I think the esr is not to low.
For now I will stick with the default regulators.
Re: Re: Troubleshooting CD67
Hi Ray,
the same idea came to my head yesterday, so I checked that and, yes, it is short to ground. I didn't notice any possible connections between RSTN pin and GND, so I thought cap CD08 is defective, but it wasn't. I lifted DAC pin 14 and it still has connection to ground :dead: I gues I need new DAC :bawling:
gy21 said:
Thanks Ray,
The 2200u works for me, no problems detected. But bigger doesn't make any sense, and it won't fit on the board. I also used Rubycon ZL/ZLH that have even lower ESR, so Panasonic FC should be fine.
A 470u/16V Black Gate will do fine too :D.
Ray.
Re: Re: Re: Troubleshooting CD67
renatas said:
Hi Ray,
Hi Renatas,
Is pin 14 shorted internally? If it's low-ohmic to ground then that would be a real bummer. But maybe the internal pull-up is screwed-up somehow? Try connecting it to +5V with a 10k or 4k7, as a last resort.....:(
Ray.
diverse outputs
After some messing around with output trannies -what diminished output levels too much- I tried Ray's discrete output stage with transistors (BC550). The results are very good, almost as good as the 1G4 tube output. :lickface:
Next step will be separate PSU's and finally the starground, still waiting for the Tent clock to arrive... :grumpy:
The setup for the new PSU will be one (4VA) 9Vac trannie with two secundairs feeding four outputs. Each consisting of a bridge rectifier (Schottky BAT85 or 1N5817) - 1.000uF Rubycon ZLH - Murata 36mH/4.5 ohm common mode coil -1.000 Rubycon ZLH - Micrell MIC29302 regulator. Decoupling on the DAC with 1uF Black Gate NX-series.
Pictures coming up soon. :film:
Re: diverse outputs
passive filter -> bc550c's buffer :D :D :D
allan
ps need to stop listening:( to continue with next upgrades
hmmmm :rolleyes:
Re: diverse outputs
Good work there disco, and I see Krall in the player :D
Was listening to that for a while last night and I was stunned in places by the realism of the piano and guitar, and how amazingly solid the bass was. Big caps defo work around the DAC and servo, even if they're not needed. And you can flame me, but I'll still like big caps :D
Last night I started looking at where to put regs and caps on veroboard, probably starting with Rowe's recommended 3 x 7805, initially they'll just be fed from the +20v. In the future these will be split up more (one reg per circuit most likely) and fed from external AC. I can't wait to see how much more can be squeezed out!!!
Cheers
Simon
Re: Re: Re: Re: diverse outputs
SimontY said:
lol! Yep, definately. It sounds great and using big uns gives me peace of mind, and it looks cool :cool:
I don't deny that a similarly pleasing result may have come from using, say, 470uF Panasonic FC caps, but I'm not prepared to risk further pcb damage by trying :smash:
Simon
I'd prefer the red head!
