Marantz CD63 & CD67 mods list
Hi again,
Can someone measure what would be the maximum diameter and height that a tx could be? obviously, allowance would have to be made for mounting.
Manufacturing cost would not be significantly higher for a largerVA rating,
Andy
Just make a big external psu, you know you want to 😉
I'm gonna put a tx or two in a big box to join my lonely clock psu's tx, and connect the unsmoothed dc to the player via a DIN plug I reckon. Then smooth it in the player, or smooth it some more in the player. The original tx may have to be removed too, but I might break something in the process.
It's a bit tight, but the empty tape-roll is 83mm.
rowemeister said:
If you remove the original TX can I have/buy it off you 😀
Hmm, I wasn't gonna replace it, sorry Brent! I was just gonna externalise it to get it away from the player. As much as anything it worries and annoys me the way it flops around when I'm working on the pcb. I broke one of the connections once... might aswell take it out and wire it so a molex connector or two, or a motherboard ATX power connector. Only slightly crap thing is the power switch would then be redundant. Hmm, I could remove the button and install some UV LEDs in there.......... hmmmm
