After a lot of testing and swapping bits I found that Q105 was half dead - pins 7&8 (laser diode) were zero volts, although 5&6 were OK at 2.5V. All surounding components checked out OK so I swapped the opamp out with ones from my old board and eventually found one that still worked. I now have a working servo section, player reads & plays disks and all the waveforms look good - just the dead DAC to fix.
Ok, that's something! Good to hear you were able to make some progress.
Hopefully a DAC-swap will bring back the music! 🙂
Bypass capacitors
Hi, i'd like to replace opamp on my Marantz CD63 and i am following the guidelines described on Marantz CD 63/67
I don't understant were to put bypass film capacitors as described in the link.
Could anyone post a picture of where they must be placed (if i undestood on the other side of the PCB board).
Thanks in advance,
Thanks in advance,
bypass capacitors
Hi, i'm trying to do some mods on my marantz CD53SE based on the guidelines provided on the link Marantz CD 63/67. I can't guess where to place bypass film capacitors.
Is there anyone can post a picture where they must be applied on the pcb ?
if i undestood they must be placed underside.
Thanks in advance
Thanks in advance
Now i have wilma 22nf capacitors ... i'am trying to guess from various pictures found on the web how to place across the electrolytic capacitors.
From what i guess is it correct to apply in the rear pcb accross electrolytic + / - connection or should i have to apply the bypass from the positive pole of the electrolitic capacitor to another point on the ground in the pcb ?
In my modest CD-67 mod I placed the 100nF rail decoupling capacitors under the opamps.
As I have understood these caps have to be soldered as near to the opamp as possible.
The film caps over lytics are something that I have never tried - I do not think I can hear their presence.
thank you so much madis64!
You are welcome 😉
However I would say that modding the opamp stages was only an intermediate step to the final solution with Ray's DOS (with signal attenuated to the level of the rest of my "old" audio gear so that I do not to wrestle too much with my tube amp volume knob when changing the sources).
Looks very interesting ... My marantz was turned off for about 10 years, it was replaced by an oppo dv980h. I am at the very first stage of upgrade and the difference is huge. I usually listen only vinyl. With the marantz you can enjoy also CDs ...
One of the first steps you take should be fixing the power sources (to whatever fancy level you decide).
Then you can spend time on listening to different opamps.
Then you should replace the clock.
At one point you probably decide to stop ;-)
You could also measure your Marantz and other players with RMAA - just to see if you can find any changes in numbers and graphs.
And more than half of my music collection is on vinyl too 🙂
Hi Everyone,
Hope someone could kindly guide me here in regards to CD63 KI troubleshooting, that I own for a good while and have modified slightly, but now has developed a problem I can't seem to trace down.
Before I continue, it looks like this problem was developing over time and until unit is barely usable now.
What happens is, at times I need to turn the unit on and off few times before the display says anything at all. Once it does turn on however, everything works flawlessly until a random point in play back (could be half disc or never) the unit would simply freeze completely with random characters lit on the display and would not respond to any buttons. The spindle turns back and forth when this happens. After that I need to switch it off and on few times before it starts up properly.
It sounds like an MCU fault... I did replace the display ribbon cable and sockets with a usual multiwire ribbon cable soldered directly sometime in the past.
I checked the MCU resonator with an oscilloscope and it reads a little low, about 3V in amplitude on one pin and maybe 1V with 2V DC offset on the other, which is different to what manual says, 5V and 4.6V with no offset. I replaced the resonator with exact same part, but measurements are same. Is controller giving up?
Any advice?
Many thanks
Any advice?
Many thanks
I have applied a decoupling capacitor between pin 4 and 8 soldered on top of the opamp lm6172. I tried one first. The opamp now is fried. Am I missing something or should I decouple v+ and v- to somewhere else point?
Before applying capacitors the new opamp works flawlessly. I was worried of course of oscillation problems and I decided to apply the 0,22 nf plastic capacitor.
I have never soldered any caps directly to opamps - my way is to solder them below the board (and use sockets for opamp rolling).
LM6172 did not stay on my like-list (after testing it out) also ...
Edit: 0,22nF translates to 220pF - are you sure about the capacity?
Sorry I mean 0,022uf, is this correct?
Correct is what you used - so what capacitor did you use?
This way or another, I have used 100...200nF caps (mostly 100nF) for this purpose.
I am using sockets but when I have applied the capacitor no sound was coming from that channel. After desoldering capacitor opamp was dead
I don't remember the brand. I've took them from farnell, they are blue with 63v
What opamp do you suggest? Opa2134?
Brand is less important, capacity is what you have to know...
As for frying the opamp - this risk comes with direct soldering to them - that is why I never do it (too old for running on edge).
You wrote that you applied the cap on top of the opamp - the only way to do it is to solder it directly to the opamp - or?
- Digital Source
- Marantz CD63 & CD67 mods list
