Marantz CD63 & CD67 mods list
Hi guys, how are things over here?
Been away for a while for more important matters. Here's the result: 😀
Congratulations Ray!
LOL @ Simon
Servo amps - I used LM317/337 at 7.5V and never had my player skip a beat, infact it tracked better after (quicker to lock onto track) but I may have imagined it. Bear in mind you have to do a bit of re-routing of the power lines for one of them. You have to isolate a track from one of the big caps to one of the amps and connect it the other side, then you can remove a jumper for your new reg input/output. It should be clear looking at the service manual layout.
The amps only output 5V signals and if you use 7-7.5V regs that's enough overhead for amp and regulator, i.e., 10V-->7V-->5V.
Bottle-fed I hope? (as a valve/tube man...)
Regards to the track re-routing;
1) Remove U234, U161 and U237 shown in red to isolate the drivers from the raw supplies.
2) Insert -ve reg at U234 (use holes as input and output)
3) Insert +ve reg at either U161 or U237 (use holes as input and output
4) Connect blue wire as shown (you can use any colour 🙂 )
Simples.
...aaaaand moving back on topic.
What have people's experiences been in removing the last traces of hard/harsh sound sound from the CD63? The question assumes you've achieved that, so most will not be able to answer this.
I find Steve's player still just has a slight bit of grit to the upper midrange and treble. It has 13 extra regulators wired directly to their consumers, upgraded caps in most places, HDAM/muting/caps bypass and HA tin hat op-amps, C1 clock on DAC, a ~80VA transformer supplying DAC/decoder/servo analogue pins, the usual chassis damping.
All that remains are low noise regs, servo re-clock and maybe a better output stage. Thoughts anyone?
Simon
ps - when I used a CD63KI as my main player it didn't have this problem, but I seem to recall the output stage helped to cure it.
I know there are a few other little tweeks that could lift things.
Examples: C505 - the HF signal goes through a ceramic cap. That should be a silver mica or at least polystyrene I'd guess.
The 10k resistors in the output filter could be matched or 0.1% items used. I might try that on my current test machine. The polyester filter caps could be changed for polystyrene, polypropylene, teflon or silver mica.
I am going to try output coupling transformers too, and I know changing the naff old sockets lifts some dirt off the sound.
There are always more power supplies to add too.
Isn't the price/sound ratio very good with the right mods? Go to shop and check what you have for 150€... nothing at all! For that I have a twin clock, regs everywhere, DOS... not that bad for me. And spare parts for cheap.
The fact there is always better is true, if you d'ont mind the price 😉
A happy CD-43 owner.
