Marantz CD63 & CD67 mods list
pzogal said:
Hi Ricardo,
what is the temperature behaviour of the Q106 right now ? Does it still get hot after replacement ?
Greetings,
Hi Pawel
No heat.
Everything works perfectly. It is now playing for 2 hours without problems.
I am starting to believe the wire mesh can sometimes cause some kind of short circuit.
Ricardo
Phoenix CD53
Hi
The CD53 was on during the night.
After confirming it was working this morning, I decided to reinstall the analog psu, connect the outputs to my preamp and... UAU.... what improvement !!!!!!
The bass has gained edge detail and the highs lost it´s hardness.
The mods consisted in replacing C111 C112 C113 C114 C115 C116 by silver micas.
Note:
I also connected my star gnd to the mains earth.
I am very happy to have identified the problem... this makes me more confident and I gained a good knowledge about drivers and servos.
Life is difficult but that only makes it more beautyfull....:grouphug:
Ricardo
Actual with new Q106 on a socket
The sound is so good I must share this image with everybody...
Next will be the Spower on dac analog. :scratch2:
pzogal said:
Ricardo-> mine Q106 becomes hot too, I just noticed it yesterday. If I touch it with the finger it feels normal, then becomes hotter and hotter until it's too hot 🙂 How does it look like in your CDP ?
As I said, no improvement in regards to tracking 🙁
Hi Pawel
I relate the tracking problems with IC Q106 itself.
Is it gets hot (too hot to touch), check the voltages on R149 R150.
If these go below +-10v, than the IC is bad.
Changing mine for a ON Semi did wonders...😉
I removed the stock IC, soldered a socket in place and put the new IC on the socket. If it gets hot again, it will be easier to replace... lol
I believe the reason it gets hot is because I have connection problems in the wire mesh connecting to the HF Amp psu.
Ricardo
rowemeister said:
Good work on the servo, clocking the servo brings even bigger gains 😉
Hi Brent
I believe I must upgrade the analog dac reg with a spower before I think about reclocking.
I have been looking to your pictures and besides the data coax mod from mech pcb to HF amp / decoder I can see you are using a white mesh for the rest of the connections.
Is this mesh soldered ? (I can not see any socket :magnify:)
Is it a special kind of mesh ?
The CD53 is now playing wonderfully and I am afraid I will face more problems with the mesh during next mod.
Can you suggest a replacement ?
Ricardo
rowemeister said:
They are from RS. They are a typical pcb connector ribbon, these are solid core too.
They are actually wider but they are easy to cut with a knife.
SEE HERE
Hi Brent
After reading a while, I know you soldered the ribbon.
From RS what should be the best choice ?
1- Halogen free ribbon
2- High Density ribbon
3- High Flex
4- Standard
Ricardo
rowemeister said:
It is a bit pricey, I have thought of selling it but the postage is nearly as much as the ribbon.
I would cut the ribbon into two pieces (8pin and 7pin).
It would probs be £3.95 (inc vat) + P&P (£1.95 to aus)
Still not cheap but it is good stuff.
First I would use some normal multi strand wire for now and see how you get on.
Hi Brent
Would you consider sending one for me ?
Ricardo
Hi Brent & Ricardo,
I had no time for scope 🙁 but I checked the pickup again, connected a lap psu, then did some forth and back travels with the pickup, added a drop of machine oil 🙂
Wobble didn't stop, but I noticed similar behaviour on my dvd player (wobble but not skipping). Then I replaced some caps in the psu, schottky diodes went in & decoupled servo & decoder caps with WIMAs. Finally put everything together and worked ! OK, I didn't check the worst CD I used for testing since my wife was fed up with the same song playing again 🙂. Anyway we just listened to some good music...
no skipping so far. I will definitely go on with the mods. Q106 becomes a bit hot. I'll replace the drivers for sure , no big cost. I am thinking of pimping the HF amp in some way. Maybe metal film precision resistors ? Anyone tried this ? The input current through R101 is very low, maybe few uAmps, so it could be prone to distortions. I also measured the voltages on the HF path and on E of Q501 i got 0.9 instead of 1.1V does it mean anything ?
Ricardo: great modding, I am afraid I won't go that far, at least not yet ,hehehe... good to hear that the replacement helped!
Greetings,
Pawel
Thank you Pawel
Upgrading caps used to decouple and smooth the +5v lines in the servo and drivers gave me a lot of detail and stopped some skipping problems.
Using dedicated PSU and sregs on the servo made a really big difference in terms of detail and bass power.
If Q106 gets hot, please verify the ribbon connecting main pcb with the one under the mech.
Keep on modding.... I did not realyse the benefits until I started building dedicated psu´s for the servo and analog output stage.
Ricardo
Haha, someone here has tried almost everything! Brent for one did this with 0.1% tolerance resistors (Holco H1 was it?). I think he found improvements to fine detail, treble, and a sense of control. The kind of improvements you also get from improving the servo IIRC.
Yeh, it's all about the power supplies!
Simon
