Marantz CD63 & CD67 mods list
Hi Higlander,
I decided to try a couple of OPA-SUN opamps in the player so will order tonight. Are they drop in replacements? For instance will they work given that I will be making the capacitor upgrades in the op amp section from Rays list, remove the current op amps, install sockets and then plug in the OPA-SUNs. Thanks.
Changing the stock opamps with OPA-SUN or other discrete opamps is done by direct swapping but don't expect a day and night difference. There will be improvement only if you have stable and very low noise supplies to them. Don't worry the new opamps will work well with all the capacitor upgrades.
Thanks. Yep, I plan to use a separate power supply running at a littl over 15vols.
I've got several sets Bursons which I've had for years.
One thing is for sure, you are wasting your time with these sorts of opamps unless you sort the power supplies out.
As soon as you use proper low noise regulators and quality local decoupling caps, they will spring into life. The quality of the supplies can either muffle the performance or can really open them up into something quite special.
Dedicated low noise regs like Brent's SPowers are the way forward 😉
You'll need decent regs too if you want to take advantage 😉
Player has arrived
Had my CD63 off Ebay arrive the weekend, was supposed to be fully functional, plugged it in, discovered the drawer would only noisily open halfway, received a replacement belt for £2 inc. delivery.
AUDIO/CASSETTE SQUARE SECTION DRIVE BELT. 35mm x 1.2mm (1 BELT) | eBay
fitted, drawer now opening like new.
I now have the headache of trying to order all the parts for the mods, in Thorstens,Rays and Bobwires lists that don't conflict and Brents parts for HF amp, also the parts for a flea and DIY clock plus lots of those little smd ceramics to put under the board, aswell as the parts for building a headphone amplifier.
Just a note for Ray regarding the clock, as Farnell no longer seem to have part 237-024 now needs to be 1827814 or 1141763 or 9411704 and 236-998 needs to be 1835001 or 3322725.
A question for anyone on here, if you are putting a led in a circuit does the forward voltage of the LED have to match closely with the voltage in the circuit.
Hey everyone.
My finding of the day : too much added weight and/or not well centered on the little round magnetic piece on top of the CD when inserted is not a good idea. Today I noticed the player wasn't able to track songs correctly with one of my favorite CD when I wanted to skip some songs, either going from 1 to 2 or 1 to 10. Removing the weight helped. I then tried to make it really round as it was not really well done. Now it seems to work as well with or without it, but I'll keep en eye on this.
so I've done a bit more soldering tonight. I've made the 12v regs for my CFP DOS board and a little clock divider too.
For the LM317 LM337 regs, I started with Ray's schematic which I'd translated into a little stripboard design. I wanted to make them nice and neat and compact.
So I started with this:
and ended up with these:
Pretty happy with how they've turned out 🙂
I'll give them a good testing before I put them anywhere near the DOS board.
I then used the Tentlabs Divide by 2 circuit schematic and some more stripboard and a 74HC74 dual flip-flop to make a clock divider so I can also use my 16mhz XO clock to run an 8mhz signal to my servo.
Coloured bits on the diagram just show where I've run wire joints.
The tentlabs instructions call for a unspecific ferrite bead on the V-in, but I don't have any handy, so I used a 10mh Panasonic choke I had left over from my DOS board components. Not certain if it's suitable/overkill, but it seemed to make sense to the limited knowledge I have. Please feel free to confirm my excellent choice/laugh at my stupidity (delete as required)
Next up is doing a few jobs to prepare the main board and putting it all together, but finding the time is tricky at the moment. Can't wait to hear the end results though. I'm very close to being finished and I've learned a load along the way as well as making some excellent improvements 🙂
Oh, does anyone have any suggestions for fuses to use for where my 2x12v 50va tx joins the board? Is there any type to avoid?
cheers,
James
which CD players used the same transport as the CD63/CD67?
Must be a few options with just buying another player cheap?
I've been considering it cos my transport, while it doesn't have any issues with reading, it always spins the discs a bit wonky and can be a bit noisy at times
