poynton said:
As the voltages are pretty much correct, I would suspect a short after the output of the second opamp to ground or a short to ground at the junction of R606/R608
Make up a temporary probe by connecting (soldering) a resistor of about 10Kohm to the tip of a phono lead. Play a disc and probe Pins 7, 1, 2/3 of the chip. see where the sound stops.
Cracking idea mate, il give it a go in the morning. Had too many drinks tonight as i got bored of fiddlign with electronics. lol
Loads !!!!!!!!!!! Just wait and see !!
Andy
PS. You did check that the balance control on your amp was in the centre not hard to the left ? [/QUOTE]
Haha one of my housemates actually suggested that. I never use that as my arcam is always set on 'direct' which has no control over the bass, treble and balance. it sounds far superior and eliminates the hiss.
LMAO
He did try the balance but it snapped off in his hand. hehe
Ad post a pic of top and bottom of pcb (opamp area lol)
Brent
il try and get that sorted tomorrow. But my camera usb connection died before the summer so its hard to get pics off. Damn technology falls apart around me.
adfinni said:il try and get that sorted tomorrow. But my camera usb connection died before the summer so its hard to get pics off. Damn technology falls apart around me.
OMG dont touch anything LOL
Brent
adfinni said:my camera usb connection died before the summer so its hard to get pics off. Damn technology falls apart around me.
LMAO! And I thought nobody could be worse than me...
Mayeb ADMIN needs to free up some bandwidth ready for all the posts surrounding Adfinnis amp hack in the morning to trace the cd signal 😱
If you want some solder let me know, i have lots, my email was a bit further back, ill post some tomorow for you m8.
Carefully check the components you removed, make sure you didnt take anything out you shouldnt. I agree with whats been suggested, first check for all the daft stuff, like lifted solder pads, scratched o/c tracks, did u remove the op amps and fit sockets (i have good ones here for u) if you did, then try swapping the opamps to see if one has failed.
best of luck
best of luck
sorry for the quality, its a housemates digi cam and it has contracted bad aids.
There you go. Hope that'l keep you happy for a while. Im not sure if il be able to get any fixing done this weekend as i might be heading home from uni.
ImSparticus said:Mayeb ADMIN needs to free up some bandwidth ready for all the posts surrounding Adfinnis amp hack in the morning to trace the cd signal 😱![]()
best of luck
o christ forgot to email you earlier. Argh. cheers for the advice mate. Il try to remember to email you about the samples tomorrow.
I think the admins need a new website just for my destruction derby full of cd-63's. LOL 😀
adam
Has anyone cared to ask how the working channel sounds?
Seeing the fuse resistors R613-R616 still in place reminded me to pass along another off list change I made that violates the hazzard warnings. I replaced the two power supply fuses (and holders) with wire jumpers. I don't know if it sounds better here, but doing that usually improves other gear.
The LM4562 opamps continue to break in and sound better (go figure). The brashness has pretty much gone. If these things cost 10x what they do, they would still be a bargain! I would not have thought they could make such the difference they have.
markk02474 said:Has anyone cared to ask how the working channel sounds?
Well it soudned noticably better to me. The bass was far more defined and less boomy, the midrange seemed to be.... just nicer sounding, and the high frequency's were less harsh.
I don't know if it sounds twice as good so it's worth teh loss of one channel altogether 😉
adfinni said:right here are some voltage readings for the legs of the op-amps. can anyone identify anything from these ? NB the right one is the old standard op-amp and the left is the opa627+ad8610 combo.
Left op-amp (working speaker)
pin 1 =-0.03
2 =1.45
3 =1.45
4 = -11.73
5 =0
6 =0
7 =0.03
8 =11.99
Right op-amp (this channel produces no sound)
pin 1 =-0.03
2 =1.44
3 =1.45
4 =-11.73
5 =-0.02
6 =-0.02
7 =0.01
8 =11.99
DOn't understand the readings on the right op-amp for pins 5, and 6, and teh minimal reaading on pin 7 (output B)
These are DC readings? It would help to measure the AC readings, preferably when in play mode with constant signal feed. Then you should be able to see the signal input/output levels on 1,2,3,5,6,7. The power feeds on 4,8 (+11.99, - 11.73) look ok on both sides. That's how I tracked down a similar problem with mine.
Pete
Tried the probe method and only pin 7 has no sound output. IL fiddle more
Plus i jsut gave myself the biggest shock of my life, and jumped outta my chair. This is dangerous and id better not fry myself.
adfinni said:Tried the probe method and only pin 7 has no sound output. IL fiddle more
Check for both a short and open circuit.
Remove the bypass wire at the chip end and reprobe.
Plus i jsut gave myself the biggest shock of my life, and jumped outta my chair. This is dangerous and id better not fry myself.🙁
So not content with blowing up equipment ......
Andy
Cor blimey guv'nor - is this the longest forum thread on the web yet?!
Have any of you chaps tried using the HDAMs in your 63's and 67's as an op-amp rather than a buffer?
I know there's no trace of them in your players now, but just wondered if you ever tried it in the past...
It is a discrete op-amp after all with the output tied to the inverting input. (100% NFB.)
Using the CD6000 OSE schematic it should be relatively easy to see where to cut tracks for the feedback loop.
I wondered if a single-stage, 4-pole filter based around the HDAM (with the op-amp section removed) would sound good.... or just use a good symmetric op-amp (half an LM6172 or AD826) for the differential amp and use the discrete op-amp for the second stage.
I've tried bypassing the HDAM completely, but unlike most of you I found the sound got better and worse in equal measure, and was entirely dependent on the op-amp in use. AD825 got better, AD826 got worse...as did LM6172. Apart from the AD825, the others seemed to lack bass dynamics and overall 'punchiness' without the buffer.
Another thought - a unity gain op-amp can be replaced with an open-loop buffer. I replaced the op-amp buffer in my Denon tuner with a pair of Burr-Brown BUF634 buffers and the sound improvement was absolutely immense. I wonder if anybody tried this in their Marantz.....
Just some thoughts.... first post so be gentle with me...
adfinni said:Plus i just gave myself the biggest shock of my life, and jumped outta my chair. This is dangerous and id better not fry myself.🙁
LOL
Do you have insurance , it must be your best friend LOL
Brent
Glenn2 said:I've tried bypassing the HDAM completely, but unlike most of you I found the sound got better and worse in equal measure, and was entirely dependent on the op-amp in use. AD825 got better, AD826 got worse...as did LM6172. Apart from the AD825, the others seemed to lack bass dynamics and overall 'punchiness' without the buffer.
I suspect people with passive preamps should leave the HDAM in, to retain the big bass, but people with active preamps are more likely to prefer the more detailed and natural bufferless sound.
I have read extremely positive things elsewhere on this forum re. BUF634. Something to try in the preamp at some point!!
Simon
ps Ad - please don't kill yourself mate
im off home for the weekend in a bit so no more fiddling will be possible. I have replaced some of the new parts with old resistors etc and still cant find the source of the no output from pin 7. I might have to totally start from scratch, reinstall all old parts with clean pads and leaded solder and test again after the weekend, as im pretty stumped to where to go next troubleshooting.
Probing parts with sound:
R606,C606, L602, R604, c602, r604, rd28 rd28.
parts without sound:
C608, r608, r612.
pins 1,2,3 have sound, and 7 still doesnt.
Right im off to pack. il be on later to discuss 😀
C608, r608, r612.
R606,C606, L602,
C608, r608, r612.
pins....3 have sound......
Indicates a possible short to ground at pin 6 or an open circuit R608
Andy
Do you have sound either side of R606?
If not then there is a short to gnd (where there is no sound).
I dont think the 10K would have gone O/C but we are talking about a serial 63 killer here LOL
If there is sound either side of R606 but none either side of R608 then you have an open circuit track between R606 and R608.
Brent
Brent
Hi Glenn2,
I noticed a reduced bass aswel when i removed the HDAM but when i changed the opamp to LM4562 the bass was back again.
I use a passive preamp so maybe the LM4562 has a better cabledrive capacity then the OPA2134 i used before.
The LM4562 is getting better by the day i have to listen to my whole CD collection again.😀
I think its THE replacement opamp at this moment !!
Ray,
I have a 42 Ohm resistor in series with the output of the opamp is it better to remove this for a thighter bass?
Ray,
- Digital Source
- Marantz CD63 & CD67 mods list
