LSK pre - BAF 2013
Those are small laterals and there is no direct replacement for them outside of the same family (2sj76,77,78,79/2sk213,214,215,216). You could use some nice verticals like 2sk2013/2sj313 but the circuit had to be redesigned to deploy them (different Vgs/Id, different tempco, etc...).
you can still get some at pacificsemi or at techdiy😎
Stupid spell correct.
Vertical is not a problem, but didn't know if the materials were similar to their larger cousins and could do with less degeneration.
Sorry Buzz, I still don't get it ...
What would you want to degenerate and what does it have to do with material (they are all silicone made) ?
Maybe you mean the MOSFET build type (verticals vs. laterals) ?
If so, why would you want to degenerate cascoding devices ?
Please try to be more specific, I'm still on level 1 when it comes to mind reading 😀
Definitely don't want to degenerate anything silicon based.
On the lateral vs vertical front. I am currently playing with a pre that has the verticals as the main gain device and was looking into whether or not the laterals mentioned above had a more favorable tempco, allowing for less degeneration in the design while still maintaining stability. Didnt know if you had any personal experience with these particular devices. Bit OT, sorry
BTW, I am not sure I know what is going on in my own mind, so you not being able to pick up on it is completely understandable, although I do have high expectations of you😀
BTW,BTW, laterals=materials(spell correct), and lateral, silicon based things are really nice in just about any application i can think of and always are a pleasure to work with in a hands on type situation.
