Low Rp tube for line stage - ideas?
I know how to measure but not how to calculate.
Thanks for the links Bela, you are right the lower fet used is 2SK3557 not BSH111BK (I was confused because I own four PCBs sorry), I do my maths:
Ale's formula:
Zout = (Rp+Rmu)/(1+Rmu*gfs)
Zout = (7600 (tube 26)+470) / (1+470x 24mS for 2SK3557)
Zout = 8070 / 11281 = 715R as Zout not far the 860R measured
I built a 12b4a preamp, tried multiple iterations and landed on my current version using Ale's gyrator and I have no desire to build anything else.
I tried a lot other preamp circuits 6sn7 01a 4p1l 2p29l and two well respected commercial preamp.
I have an old commercial pre based on 12b4a and its a wet dog. Wouldn't mind improving on it . I can use plate choke or anode current source or both and tweak it a little. I don't want to hack the design completely.
Psu is a 83 valve plus RC string. Regulated 6.3V filament.
I just finished a 6C4C line stage which is very interesting - exceptionally lean, clean and detailed. Just about the complete opposite of my 26 stage which is full and lush. It's different from anything I've heard or built. Intriguing. For what it does it's quite remarkable, but it isn't full and lush at all. Very good on classical music and piano, wide precise soundstage. Dynamic and effortless - it's an output tube after all. Low gain and 800 ohm output impedance. Svetlana quality tubes. I could probably put more current through it. KBG PIO output caps.
Why don't use the 6H30 , beautiful linearity and 800 ohm of Rp, mu of 16-20?
Or 6N6, sister of it?
In Srpp with point of job a the upper limit?
Walter
If you want a line preamp with gain of less than 10X, and you don't want to use negative voltage feedback, then 6N30P and 6N6P will end up with too much gain (at least 12X, even with cathode degeneration). That's why there's interest in using power output tubes for a line stage. There are several on diyAudio including a 12B4A version, a 6V6-triode version, and several others. 4P1L-triode also fits this category, but I know andjevans has tried that and other similar things.
Reactions: andyjevans
