If the noDAC's powered from 5V then it can't reach 2VRMS. I forget what the maximum modulation for DSD is, is it something around 70%? In which case with a 5V supply you can reach 1.2VRMS. If its 50%, then about 900mV.
I guess you want to say the Amanero, if yes it's powered with 3.3V but the Chronus re-clocker it's powered with 5V.
I think the best way to get maximum signal would be to run balanced output - two filters per channel, one fed in-phase and the other anti-phase digital data. Then buffers, then a transformer between the buffered phases. With a 5V supply you'd have a chance of putting 2VRMS into the trafo.
Using a flip-flop degrade the sounds quality.
I'm looking for an total output 2Vrms like any standard output DAC.
Here's a variant of the noDAC filter designed for use with an active buffer (Zout is 4.7k). It has a loss of only 0.2dB.
Could I use with active tube amplification?
Hi abraxalito, could you provide the inductors?
- Digital Line Level
- low pass filter for DSD
