Richard I just loaded the software via file and printer sharing over a wifi network and ran it on a win8.1 machine. It even works off the touch screen to my surprise.
I guess .Net is included with the newer win versions.
Yes it is.
But I cant get your file to open on Win8. BUT, I installed it on my old XP and it is working!?
We can figure it out later.
THx-RNMarsh
THx-RNMarsh
Yes it is.
THx-RNMarsh
Sure. You can try the oscillator on your XP machine.
You can open the folder on the CD with your file manager. Click on the folder Application GUI. In that folder there is another folder named X86. Try that version of the build. it will run as a 32 bit app on a 64 bit machine.
Just did a bit of research on the .Net problem. Win8 came with .Net4.5. Users say try updating .Net from windows update to latest version of .Net 4.5 to resolve run issues.
My win8.1 laptop has the latest version.
Work in progress - status:
Ok I will try that. I am running your osc from the XP and running the Audio-Prec from the WIN8 machine.
So far I learned the 2H can be as low as -135dB with 3H at -138dB (1KHz). These are very good numbers. Also, there is very short settling times for all freq including low freqs.
The distortion is a little higher on some ranges... something for you to look at, perhaps.
I'll get more info to you by regular email until the prototype is the way you like it.
THx-RNMarsh
1KHz
1KHz and 5KHz
THx-RNMarsh
Great--the distortion is surely near the residual of the SYS-2722 analyzer (or beyond)! What about THD+N?
Samuel
PS: I wouldn't use the AES-17 filter unless really necessary (e.g. ADC or class-D amp testing), it slighty worsens the analyzer residual.
Samuel
Comparing to resistive tuning the Mdacs seem to exhibit a slightly higher distortion depending on the output current of the dacs. When the dacs are closer to their extremes the distortion
decreases. Therefore for the same frequency and different range overlap the distortion may be different.
I do observe distortion differences in different range overlapping with other oscillators.
339A for example.
Another possibility is that if you're at the residual of the analyzer the sum-difference of phase of the harmonic between oscillator and analyzer might be showing their face. ther can be phase differences between same frequency in different ranges.
339A for example.
What about THD+N?
Samuel
On this range and this level and freq.... about -113dB
(all outputs are from the 0 degree output or the BNC on the right)
[Open the top/first picture by clicking on it. then click again for magnification. Then move the curser around with the mouse show the details of the analyzer display.... there is a THD+N window showing about -113]
The notch from the A-P is showing -155dB.
THx-RNMarsh
THx-RNMarsh
View attachment 427947 1KHz
View attachment 427946 1KHz and 5KHz
Is a flat top window what you normally use for FFT in the AP?
Very low distortion --
Here is the FFT of 2H and 3H on the 100Hz range but still 1KHz.
I noticed something.... at levels far below -100dB the noise is beginning to have its affect.... namely, that the A-P doesnt always recognize a small change in osc freq. If I just change 1000 hz by +/- 3 hz, the AP may not track it and the Harmonic level being shown can go up .... using the 3H first. But sometimes, both can be up a lot more than is real. So, gentle people, we are near the measurement limits for accuracy.
What you see is from my 'bumping' the A-P notch filter back and forth until it was stuck at the center of the osc freq and thus the lowest distortion results.
Thx- RNMarsh
Thx- RNMarsh
Maybe some gain before the AP would help. Most analyzers would have the same difficulty.
Samuel knows all about the APs. Let's see what he has to say.
These are indeed very good numbers. Congratulations.
I think in a real world environment, the AP is reliable down to about -114 dB. The measurement part is better, so the figure I quote is system performance.
Thanks Bonsia. That would hold true for most analyzers. Can't figure the 339A can measure down to 10uVrms FS but is so limited in distortion measurement. Noise dominates.
Yes, if talking about THD+N.... A-P spec says it is 'typically' less than -115dB.
David's software frequency control panel via USB. ->
THx-RNMarsh
I noticed something... At levels far below -100dB the noise is beginning to have its affect... Namely, that the A-P doesnt always recognize a small change in osc freq.
The counter (which is used for the coarse notch frequency tuning, usually) will stop working correctly at very low levels. The auto-tuning might still track the signal frequency, but as it tunes further from the nominal frequency, the distortion increases. That's probably a result of the used multiplier--I don't know what they use.
Samuel
Samuel
Then some extra amplification used for very low levels to the counter would help?? Or, is that too much over-simplified.
THx-RNMarsh
- Design & Build
- Equipment & Tools
- Low-distortion Audio-range Oscillator
