lm 3915 vu meter problem.
shorted capacitor?(without a meter it's impossible to tell)
inverse polarity on the diode?(ditto)
just because a part looks physically ok doesn't mean it is.
resistors can be open or off tolerance but look ok.
so without a meter how can you be sure the parts you added including the diode are ok (and the right way around)
Spiny
Resistor between pin 7 to pin 8 is 1k
resistor from diode to negative is 100k and other resistor from diode is 1k. capacitor im using is 1uf and capacitor positive connects diode cathode and negative to ground :/ When i connect my audio to pin 5 everything works but only 6 leds blink... when i connect to diode all the leds immiadetly turns off
Its working - Reverse the diode and the leds should blink.
Try some different cap values like 0.5uf (0.47 will be preferred value) or 0.047uf (47nf) once it is working with the diode, a 1n4148 is fine.
To check all are working connect +ve to Pin 5 (or the diode)
I suspect the reason the last few are not working is a peculiarity of the breadboard. This type has the power lines split in the middle, you need to connect across the gap. See attachment.
Sorry I missed that earlier. With a meter you can check continuity. Handy gadgets, like most folks here I have several mainly cheap ones and one expensive and calibrated one to check the others against.
see this which I think is the type you have.
electronics introduction to breadboards
alan
its pretty cheap turk. like 10 euro 😀
tryed reversing the diode and after i touched the my audio wire to diode i could hear cracking sounds😀 i dont think so thats supposed to happen.
Tryed to connect those power lines together but still nothing ;/ Hmmm strange.. i guess if i connect my audio to the diode something should happen no matter 1uf or 0,5uf.. but now nothing happens at all.. not even first led blinking. i might missed some connections but everyyything seems okay without multimeter
You need to connect the power lines, removing the 100K resistor will cause the capacitor to hold its voltage - and the display is showing the voltage climbing.
What are you using for audio? as it is this is suitable for loudspeaker output - and it would be loud! to light all the LEDs
Check the 100K really is should be brown black yellow for the bands on a 4 band resistor (with silver/gold as the finaly band) the image is not good enough to read the bands so can not tell.
alan
if you had a meter you'd probably measure that resistor and discover it's 10 ohms (what looks like orange is actually gold (5%)or possibly faded red(2%))100k should be brown, black, yellow the 4th band is tolerance
your shorting your signal to ground
