That's how I understood it too.
http://www.diyaudio.com/forums/everything-else/267760-lm-3915-vu-meter-problem.html#post4227292
Folks, what does this bit mean exactly.
"I use 9V power source
3,5V , 0,02A 10leds"
The way I see it you're not getting enough current to drive all the leds? I would suggest the LED supply should be capable of at least 200mA (or 10x LED current) and more if the bargraph chip and preceeding opamp circuit are using same supply....
I didn't see any answer to #56 - the use of a dropper resistor in series with the LEDs supply is dubious but the '3915 data sheet does recommend a 7.5ohm in series with the LEDs and 2.2 uF Tantalum (could also be electrolytic) from junction of LEDs/series resistorto pin 2 (0V). personally, if i found I had dissipation problem, I'd use a 78M05 (5V, 500mA regulator) for the LED supplies.
can you upload pic's of what you have wired up?
get a multimeter yet?
sorry don't know what your question is about the resistors is (did you mean - "variable" as in a "potentiometer" ?) cuz nobody says they have to be expensive?!!
are you still unclear as to how this circuit works ?
and what are you using to power this circuit ?
well if you look at some of the diagrams the supply voltage for the LM3915 is listed as: 12 to 20 Vdc your already 3 volts below minimum and if you've run this on the same battery for a while... i hope you have "fresh" spare's available.
anybody want to spearhead doing some crowdfunding so we can get lukutis a multimeter
if you have a 1k from seven to eight but neither are referenced to ground i'd be at a loss to explain how your getting any display...
resistor 7 connects to 8 and 8 pin connects to negative.. so i guess that okay then? Yes i saw in some circuits that people use 12Vdc but man.... i dont have any idea how do i run a circuit with 12V . I saw some videos where people build their transformer for 12V but that seems like a hard task for me![Big grin :D :D](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
- General Interest
- Everything Else
- lm 3915 vu meter problem.
