Lightspeed Attenuator a new passive preamp
The one and only
Joined 2001
While I was at it, here is a version for two channels worth of LDRs.
R3 and R4 assume higher values, but I'll leave you to figure that
out experimentally.
The one and only
Joined 2001
OK, this would be the last manual version that you are
likely to see. It has all the pieces, and allows pretty complete
adjustment of input impedance and range, top to bottom.
As a 2 channel piece, LDR1 and LDR3 should be matched to
each other, and LDR2 and LDR4 should also be matched.
The match should take place around the 5 Kohm resistance
value. LDR1 and 3 do not have to match LDR2 and 4.
Stereo LDR Circuit with Buffers
As posted by Mr. Pass here's the stereo circuit in detail. Let me know if I missed something...:cool:
  • stereo ldr circuit with buffers by nelson pass.zip
The one and only
Joined 2001
Tolu said:
I thing this Lightspeed version has too less attenuation (-40dB) when you put the powerful JFETBOZ (+22 dB) behind it!
I deliberately chose -40 dB because the tracking was still pretty
good. In the lastest version, you can adjust the range pots to
get down to -70 or -80 dB if you want.
And of course you can have less gain in the JFETBOZ without
any difficulty.
The one and only
Joined 2001
Re: jboz buffer
Harry3 said:
As there are a number of TL431 types available, what is the prefered version?
It's not important. I suggest you use the one in a TO-92 type
package, as the surface mount ones are difficult to work with.
albertli said:
nt any gain from the jboz. I just want the connection as follow:
" CD - Lightspeed with buffer - poweramp with 12k input."
I thought I'll need a buffer with 600R to 1K output, am I right?
If by this you mean the 1K resistor already at the output of the
buffer, you'll be fine. You can play with other values, but at some
arbitrarily low resistance the circuits become prone to oscillatory
interactions with the load.
That's where I've seen this buffer before, Pioneer used it as well on the rear end of their top shelf "Stable Platter" cd players like my old PD-77 PD-75, they wanted to keep the poor old NE5532 isolated from the outside world, so they buffered it with this Fet buffer. But they kept it within the feedback loop, and they also used a NP "Nelson Pass" :rolleyes: coupling cap.
Cheers George
So what do you guys think is the best option for me?
I have a sony cdp x3000es going straight to an old old marantz 300dc power amp which I think is only 33k input impedance.
My question is which option should i go for/be best suited to my setup? the standard lightspeed clone or the buffer version???
also the power amp has dual pots for tuning each channel does this mean i wont have to match the ldr's ?
Hi, the pots have to go, this is the whole reason behind the Lightspeed.
The easiest/best way is to sub the 33k resistor for say 68k and bypass the pots in the Marantz, but never power up the Marantz without the Lightspeed or another preamp attached, just in case it's a bi-polar input amp and not Fet.
Or do the buffer after the Lightspeed and just bypass the pots in the Marantz which will be a compromise compared to the first option, but still better than any other way.
Cheers George
Nelson Pass said:
Hi, I'm late for this thread, may I ask a stupid question?
Are those 2 resistors of 150k (R1 & R2) there for reducing the current on the LDR's string, and making the voltage divisions by the VR string significant enough?
But, they also significantly reduce the voltage and current seen by the LDR's, wouldn't they?
So, the LDR's would never fully turned on, and there'd always be some degree of attenuation even if the VR is turned fully CW.
If I need this without the "buffer" stage, how can I modify the circuit?
Thanks a lot:)
NSL-32RS2S optocouplers
Hi friends,
I just get received the package from Allied Electronics included ordered NSL-32SR2S Silonex optocouplers. I just see in the box 3 different types of ordered optocouplers !?. I clearly see on the body of each one following printed numbers & letters : "387 R2C" and "307 R2E and R2G". On the www of AE are on the attached photo "364" numbers. Did they sent to me proper optocouplers ?
Hi Krzysztof, just try to make both channels of the series the same letter and the same for both channels of the shunt, this will give you the closest resistance match, the number is just a batch number. See spec sheet attached.
You will still have to hand match the pairs, there is no free lunch when building the Lightspeed Attenuator.
You have to take the pain to enjoy the gain.
BTW don't forget to vote for a Passive Preamp forum here.
http://www.diyaudio.com/request/
Cheers George
  • nsl-32sr2s data sheet.pdf
