Legato 3 - Look ma! No caps!
Hello Russ,
as an owner of different Buffalo, Ivy and Legato 1 and Legato 2, and waiting to mod both, I would kindly like to know:
- when will the schematic of Legato 3 be available?
- does the replacement of the three parallel BS250 with TP0604 have a different result in terms of measurement (ex. THD, slew rate, bandwith) on a Zload of let's say 4,7K (the ballsie inputs), or just they perform better only on lower otput Zload or both?
This is just to understand if it is worth to replace again all BS250 with these new devices.
Thank you in advance!
GM
GM
Good question! As owner of different Buffalo, Counterpoint, Ivy and Legato 2 it will be interesting to know for me too.
Thanks Brian... I figured that was the answer I just wanted to make sure. I am trying to have no opamps in my rig this time.
I've found a tube BAL/SE circuit with unity gain so I'm thinking of trying that but now that I think about the ventus I may build that as well.
Darn it, you've sold another module. There goes the Camaro fund!
Nobody can help me to understand what below? Are these so odd questions?
Thank you!
Hello Russ,
GM
Kits are being assembled now...
