Lazy Singing Bush
A salute to ZM, beautifully organized kit complete with non-trivial requisite customs documentation, and
Seasonal Easter egg postage stamps!
I am compelled to ask:
What is the origin of the name "Lazy Singing Bush"?
And we start again. I made a careful component inventory referencing the kit list, parts bags and schematics. Completely accurate thank you.
@Zen Mod question for you re Mu resistors:
Should 3W MOX in R4 R6 R8 R10 R12 = 1R?
And 3W MOX in R5 R7 R9 R11 R13 = 1R5?
Schematic in post #1 here indicates 10x 1R, I've read the subsequent posts on adjusting the values.
I'll be running the THF51S.
Thanks in advance!
@Zen Mod that was highly informative. I think the "for he's a jolly good fellow" emanating from said bush is meant for you. Invisible Swordsman would be a really cool name for an amp.
Question: Which specific thermistor x 4 do you recommend for your Handy Addendum PCB's?
CL60
if you have single primary, use one
if you have dual primary (connected in parallel), use one per primary, so two
Thanks ZM and Ben! Mu resistor popsicle
Well that's just genius. I had to give it a try and sure enough the toung depressor size works as well.
What a great solution to something I know I struggle with. Worked great and slid right out after soldering legs!
Thank you @JKiriakis !!!
@birdbox glad that worked out. I have used carboard or toothpicks in the past which don't work as well as popsicle sticks. Yours are even better.
@Zen Mod two quick questions please:
1) how do I orient OK1 which is the 4N35 on the Mu PCB? (EDIT - found the pinout diagram, I see now the dot on the device is adjacent Pin 1anode which connects to Pin 5 collector on to the positive side of C2)
2) is it advised to pre-set trimpots P1 (5k on the SIT board) and 10K on the Mu board)?
Thanks in advance!
Next question: I am awaiting two Pass DIY tribute chassis from Gianluca at Modushop. Monoblocks planned for the Lazy Singing Bush THF51S + IXTN40P50P
I see they are 4u/400 deluxe configuration, so two piece heatsinks.
Reading elsewhere in the forum, I believe it will be necessary to add aluminum flat bars to provide good dissipation from each device on each side of each monoblock.
1) Do you think 3/8" x 4" by 12" flat aluminum flat bar stock mounted to the sinks will work for me? That's 9.525mm x 101.6mm x 304.8mm
I can go thicker and wider for a bit more money.
2) Wise or necessary to add thermal paste between the flat bar stock and heatsinks?
Good thinking - with just one OS part per side, you need spreader
1. 9,525mm is ok; if you cab choose - say that 150x200 mm is better than 101x300
2. better with than without; take care to have it in thin layer and enough screws; min M4 screws, and no need for fatter than M4
Next question please:
What is the value of the flying resistor directly attached to the gate of your THF51S?
Any need to remove R16, R17, or change their values when using the THF51S?
I did order the aforementioned spreader plates, now 150x200mm. How many M4 fasteners per plate would you advise?
Thanks ZM!
ref to schm in post #1
R17 used only for Schade osfe, so not fitted for THF51 or any other SIT
flying resistor, ditto to gate pin of SIT, heatshrinked properly, value 47R
if that, no need for R16 on pcb, solder wire (leading to flying gate resistor) to "G" wirepad on pcb
150*200 spreader plate ......... 8pcs of M4 screws/bolts
Reactions: JKiriakis
Starting PS build.
ZM, do you recommend adding two tall white Ducati bypass caps in parallel, a la your LuDef example elsewhere? CLC as you see here below.
And, I see the Mu Follower PCB has vias for an additional cap denoted C** and C*. I have some big film caps in stock, Would those be good (rated to 75V), or do you have a proposed part?
Many thanks!
