L'Amp: A simple SIT Amp
Pass DIY Apprentice
Joined 2001
Joined 2000
L'amp CCS Resistor Values
Hi Mike and All,
Can you tell me the wattage on the 1 ohm resistor after the IXTH6N50D2?
Is it 30 watts? 19x1.6= 30.4w ? The heat sink in the photo has a serial pair that look like 3w resistors, but I am unsure. Is the mosfet taking most of the current?
R1 is typical 3w?
The rest are 1/4w at the gate of the SIT.
Thanks,
Vince
Joined 2009
I have build up the second channel of the L´amp, means the Hammond version, so I had the pleasure to hear the system in stereo.
Hearing mono, I found the inductor solution a bit too dark for my system, now in stereo the sound balance is very good. I do not know why, I even suspected a phase failure, but all is o.k.
The comments of Chris and juanitox described the sound of this solution in contrast to the thick film resistor solution, so I have nothing to add.....only that I am impressed.......!
At the moment I would say that the CCS solution, especially the solution B with the Semisouth described in Mikes CCS.pdf, is situated between the thick film and the inductor solution and also very worth a try if your system does not need the bass boost and body of the inductor solution, you gain a bit more solution and presence.
And of course Nelson the sorcerer must have a solution in his SIT-1 that it sounds not too thin even using thick film resistors....:cool:
But for open baffles needing some boost from the current amp the inductor solution is great.
I must still change my battery driven bias solution to a small PSU solution.
I am sure my Jazz Friends coming next week will let their mouths open after hearing the SIT amps, what do I want more.....:D:D:D
Official Court Jester
Joined 2003
thanks Zen Mod,
I hope you will soon find the time to build your Zen SIT amps!:):)
yeah .......
exciting times are in front of me ..... as always
and , as usual , I don't have either time/need/motive to make any of Babelfishes for my self .... there is always new koan for poor ZM
it seems even BJ2 will have same destiny
