kx1200.1 help
Put one FET in each bank on the side that causes the a protection issue. Remove the toroid inductor L105 or L106 on the side with a problem and power up. If this allows the amp to come out of protection, the inductor may be causing an issue.
I didn't see anything obvious.
Based on the following link the PBHV8115 and PBHV9115 appear to be replacements 8115 for 4373y and 9115 for 1661y.
KTC4373Y npn smd sot-89 transistor complementary pnp, replacement, pinout, pin configuration, substitute, smd marking code CY, equivalent, datasheet
Now its cycles in and out of protect with fets in on either side. Im making negative progress. im stumped. I replaced the driver transistors with PBHV8115 and PBHV9115. Do you think that might be the problem?
When you say "that resolved the issue" Do you mean the amp came out of protection? Was there ever a condition when you had drive on one side or the other?
Replace the Inductors, and remove all of the output mosfets. Lift R11-10k ohm. You will find it near Q10-3875GR. This should disable protection. If amp Powers up, check for drive/ squarewave at the gate resistors. Post screenshots for all banks.
Q113,135-A1361, Q104,126-C3503
