Krell KSA 50 PCB
I saw the Rikens' length problem but it isn't too much of a problem - for such as small shortage I usually just bend both legs in a little under the resistor, with only 2mm or so increase per resistor. Otherwise just use Holco's, or perhaps the AudioNote Tantalums which I originally chose but ditched for just being too expensive.
There's always this method as well.
Good for heat. PITA to do al the bending though.
-b
Upupa Epops said:
If you are aesthetic, go to the haberdashery and buy there glass beads or small glass tubes. These " devices " are ideal for making perfect distance over PCB. 😉
What about the skin effect and dielectric properties of glass near the resistor? 😉 The next thing we will hear is creating pseudo tone controls from glassbeads and polyester fibre....
MPSA42/92
Pinkmouse,
I haven't checked the voltage and current ratings, but assuming those are in line with the 35v rails, I'd bet they'll work.
I'm from the Medway towns myself, though I live in Santa Cruz, Ca now. I'm going to be flying in to visit with family in a month or so, is there anything I can bring/carry? If you have anything in mind you should prolly email me, rather than pollute this thread...
Stuart
Re: MPSA42/92
WorkingAtHome said:
Not sure if these are jokes about not tilting the resistors, or about bending the leads. The method used in the pic I posted was only used for resistors that get warm. Regulare mounting was used otherwise.
-b
Stuart Easson said:
Pinkmouse,
Stuart
Gents, I am sure they will work, however with the gain being lower than original components... I will stick with higher hfe components. Also marrying different types of components masks the coloration that occurs from using one type of component.... unless you like that kind of character.
Since i'm interested in the minute details..
K-Amps,
What parts will you be using? I'm interested to know now 🙂
I'm using motorola 15030/31's for the drivers for the outputs, i'm yet to source a bias transistor (i'm sure one of the ones i've got will do fine), but how much "difference" realistically would having different chips (other than mpsa) make? What ones will/have you planned to use?
Aaron
Re: Since i'm interested in the minute details..
NUTTTR said:
K-Amps,
Aaron
Will use the MJ15032/33 instead of the older 30/31. It has higher and more linear gain. Also made with different processes. May go for 34/35 but it depends. For OP devices, will go either 21193/4/5/6 or MLJ1302/3281 or even 4302 and 4281.
For inputs will try the MPSA 56 /06 if not the Krell specified ones.
Higher gain devices can be an issue sometimes but sonically I have found them superior in most if not all installations. They have less glare and electronic hash. Sound softer and mellower.
