Krell KSA 50 PCB
PMik said:
Luke
Just use 0.2 Ohm value if you prefere to do that 😉
I prefere 0.1 or 0.15 Ohm emitter resistors,
AuroraB
True class A for 50watt/8Ohm demands 3.5 Amps idle current :hot:
A more "human" approach is to go for 2.5 amps idle :angel:
Crunched some numbers:
Inputs
Number of output devices: 2 Pairs
Voltage rails (per rail): 45 volts
Emitter resistance (per device): 0.5 ohms
Bias voltage per Emmiter resistor: 450 mv
Idle bias per device 900.0 mA
Speaker ohms 8 ohms
Results
Idle bias per device: 0.900 Amps
Total Amplifier bias (per rail)** 1.80 Amps
Total Amplifier bias (both rails) 3.60 Amps
Total Dissipation (per channel) 162.0 Watts
Dissipation per device pair at idle 40.5 watts
Class-A output: Peak 103.7 Watts peak
Class-A output: RMS 51.8 Watts RMS
Efficiency 32.00 %
Max Class-AB RMS (1 kVA Toroid p/CH 5% reg) 115.16 Watts RMS
Or if you want to use 0.22 ohm ER:
Emitter resistance (per device): 0.22 ohms
Bias voltage per Emmiter resistor: 195 mv
Idle bias per device 886.4 mA
Speaker ohms 8 ohms
Results
Idle bias per device: 0.886 Amps
Total Amplifier bias (per rail)** 1.77 Amps
Total Amplifier bias (both rails) 3.55 Amps
Total Dissipation (per channel) 159.5 Watts
Dissipation per device pair at idle 39.9 watts
Class-A output: Peak 100.6 Watts peak
Class-A output: RMS 50.3 Watts RMS
Efficiency 31.52 %
Max Class-AB factor (100%=ideal load, Krell/565's = 91%, 555=70%) 91 %
K-amps said:
Paralelling 0.1 is 0.05 ohms not 0.4 ;-)
Remember, many people still think the KSA-50 is one of Krell's best sounding and one of Stereophile's top 10 power amps of all time. ;-)
I would stick with the stock ER's unless you want to play around.
:angel:
Your arithmetic is correct. Read my post again (and the one I replied to) and you'll see that mine is too.
What sort of resistors are you getting, Luke?
Slap me if this is off-topic, but would it be sensible to reduce the supply voltage and increase the bias to suit lower impedance speakers, or just lower the voltage to reduce dissipation/cost?
Would the driver circuitry be happy with, for example, 30V rails? Or would it make sense arranging separate supplies for driver and output (45V and [whatever])?
Cloning this well-regarded and hugely expensive amp is worth doing, for sure, and I take K-amp's point that it's too lovely to change, but how down-rateable or tweakable do y'all think it could be?
I would tweak it somewhat. Like I would use newer devices with more stable gain. (the Mj2119X are good choices) But I would not assume that my mods will make an improvement, if it does, Good if not I go backcken.
Also I would probably not reduce the rails too much, after all headroom is another thing Krells are known for. But to your point, reducing rail might make the sound a little less harsh maybe.
with 30v rails (I am assuming, fully loaded rails the are 30v not 30v unloaded) you will get a max of 50 watts with nada headroom. You will also need a huge Toroid. Just a few things to consider.
In the end it may depend on what parts you have scavenged.
30V supply is too low, - 50W into 8 ohms is 28,2V peak. 35 V is minimum in my opinion, but then of course idle dissipation increases as supply goes up.
K-amps... your calcs are OK, but the combined 1.8-2 A idle will flow through both halves... theoretical minimum idle will be 2,5A for 50W into 8 ohms in true class A, which makes my toroids just about good for a 50W amp, as the trafo is spec'ed at full load. Obviously, a larger trafo would make for a stiffer supply voltage, but at a cost,- price....
Maybe the frontand should be ragulated ?? any thoughts ??
ACD, - which design voltage was used for the driver section ??? Are the component values true to the original, except for the transistors ??
I wasn't hoping to get 50W out of a reduced supply voltage, rather to get similar performance but at a lower power.
By the way, there are a couple of inconsistencies in the schematic/layout:
-on the layout Q108 is labelled Q106
-notes on schematic state that Q107 and 108 must be fitted with suitable heatsink. This should read 'Q109 and Q110'. What thermal rating is required?
Agreed, Also a class-A amp loaded rails at 30v are much stiffer than a class-AB PSU with the same 30v voltage. (This ofcourse assumes the PSU is designed according to dissipation requirements).
Also to get 50w from 30vdc, you will need a huge trafo... 800VA to 1kva otherwise you will not get 50 watts.
It's possible, but I'd rather have rails of 42-45v and have some headroom... don't like clipping too much here...
As I said, I'm not expecting 50W from 30V, just something smaller but similar sound. Call it a KSA-25 if you like. I also mentioned that I realised that the driver might have to stay at 45V, that I was prepared to try just reducing the volts to the output stage.
AuroraB implied that even in the original KSA-50 the drivers and output might not be the same rails - can anyone confirm what the driver stages require?
I don't understand 'Also to get 50w from 30vdc, you will need a huge trafo... 800VA to 1kva otherwise you will not get 50 watts.', not that it matters because I'm not trying to get 50W.
Apologies if it looks like I'm hi-jacking the thread (cloning the KSA-50); should I move it to a new topic called 'baby KSA' ?
btw...I am right in thinking that this is a class-A amplifier...?
Attached you find the schematic whichs I got from Bra (the threadstarter) 😉
