Hi Klass,
To220 and isolation/thermal pads are compatible.
Modify your torquing technique to stay within the tightening specification of the component manufacturers.
One other point to look out for are sharp edges on the components that could/will dig into the plastic insulation material. Remove any burrs that are present.
Some builders suggest honing the backs of the contact surface completely flat . 600wet/dry silicon carbide paper is pretty good for this.
You're right Andrew. this happened almost 15 years ago, you could call me "mechanically challenged" back then. Doing mechanical work for 13 years set me straight in that respect.
My point was mainly that simple mestakes can be hard to diagnose given the right circumstances. In this amp the output-signal was on the mounting-tabs of the to-220's (hexfets) so the arcing only occurred when playing loud. Afterwards there was no sign of arcing on the hexfets or the heatsink, just the burnt-out hexfets .over and over and over again...
With kind regards,
Klaas
With kind regards,
Klaas
Ok, I think that people have had enough time to see my offer on the badges so why not put up a final date to express intrest?
today is Tuesday, may 30th. I'll set final day to this Sunday June 4th.
This is what I have gotten this far from this thread, If I have missed someone then please Post to remind me.
AndrewT
2pc Small
GeWa
2pc Small
2pc Large
rjkdivin
2pc Small
domible
1pc Large
dr.strangelove3
2pc Large (no number?)
pinkmouse
Xpc of what?
LyckyLyndy
Xpc of what?
Ryssen
Xpc of what?
gaborbela
1pc Large
AndrewT
2pc Small
GeWa
2pc Small
2pc Large
rjkdivin
2pc Small
domible
1pc Large
dr.strangelove3
pinkmouse
Xpc of what?
LyckyLyndy
Xpc of what?
Ryssen
Xpc of what?
gaborbela
1pc Large
Hi Kmj,
if the "CRIMSON 1704" and "Leach 130st" can be substituted on the small plates without a logo then I need 2 off each style (six in total)
Hi Kmj,
I'll look into it. You will probably have to pay a bit more since those aren't the same as the other batch. I'll get back to you when I've checked.
You did mean just a plain text, right?
lgreen said:not talented enough to complete
Dude,
Are you not the one with the geared pre-amp ?
And the one who turned a toaster in a digitally temp-controlled Krell amplifier ?
And the one who showed beautifull butterfly pics of production quality Aleph-X's ?
Fix it, you whimp !
Update
AndrewT
2pc Small
GeWa
2pc Small
2pc Large
rjkdivin
2pc Small
domible
1pc Large
dr.strangelove3
pinkmouse
2pc of Small
LyckyLyndy
Xpc of what?
Ryssen
1pc of Small?
gaborbela
1pc Large
johnm
1pc Large
AndrewT
2pc Small
GeWa
2pc Small
2pc Large
rjkdivin
2pc Small
domible
1pc Large
dr.strangelove3
pinkmouse
2pc of Small
LyckyLyndy
Xpc of what?
Ryssen
1pc of Small?
gaborbela
1pc Large
johnm
1pc Large
I´m in for 1 small.
hope i can pay in SEK.
Sure thing 😉
Pinkmouse, can you put that in the post above as well?
Ryssen said:hope i can pay in SEK
1 Dollar, 2 DollarS
1 Euro, 2 EuroS
1 SEK, 2 SEK ?
Hi! 😀
Dollars PLEEEEASE.
And badges. The thing that limits them is the presence of a Logo. That has to be in Vectorformat. As long as it is plain text all he needs is an Exelfile with the text exactly as you want it.
As an example, if it says "Krell KsA50" then thats what the badge will say (not KSA).
So, AndrewT.
You can have your leaches 😀
just send me an Exelfile with the text you want. Have in mind that you need to write it in the correct size and font. As long as the physical size doesn't differ, your in the clear.
Dollars PLEEEEASE.
So, AndrewT.
Well not trying to be a stick in the mud. But I plan to buy one small that would be for the KSA 50, but would like another one, for my future project, the KSA 100. So what do I do? Do I just order two small, with the KsA 50, one for me and one for Mark. And then hope we do an order for the KSA 100 down the road? Or is their enough space for me to scratch KsA 50+50 on the small or large plate?
Sorry if I am nitpicking. Three days away from summer vacation and I get my first driving ticket ever, in 37 years. They put a new stop sign during the Memorial Weekend, and there was a cop just sitting on that little goldmine. Now its court time during my vacation days...
Hello you stick-in-the-mud 😀Well not trying to be a stick in the mud.
Well, you could scratch in +50 if you want but take a look HERE (easier than quoting)
The text-part can be altered and still made in the same batch.
So, badges with the "KSA-50" substituted for "KSA-100" can be made in the same batch.
So, If anyone want badges for the future KSA-100 projects that is OK too.
AndrewT
2pc Small
GeWa
2pc Small
2pc Large
rjkdivin
2pc Small
domible
1pc Large
dr.strangelove3
pinkmouse
2pc Small
LyckyLyndy
2pc Small (LL&Mark)
1pc Small (ksa100)
Ryssen
1pc Small
gaborbela
1pc Large
johnm
1pc Large
Ed Lafontaine
2pc Small
- Krell KSA 50 PCB
