Klein Bottle enclosure
after checking out Acme Klein Bottles i was wondering if the shape could be used as an enclosure for a fullrange driver possibly creating a backloaded horn assuming an exit is created.:scratch1:
i do want a klein stein for a beer mug!😛
sy thanks for that link i guess it's been done in a larger scale then i was thinking of by a wide margin.
cal i was thinking the other way around; mount a small 2 or 3 inch wideband driver on the small (throat) opening and create exits around the driver into the large part (mouth).sealed could also work...
now i need to find a 3D printer!
or maybe just get some klein steins pour out some margarita's wait for spring and think on it somemore....
A Klein bottle is closed if you put driver at mouth. In which case it will be kind of like a sealed TL (if long enough). One could mount driver on wall of bottle and let mouth/neck serve as vent in a BR or TL or BLH. The aesthetics would look great in a real blown glass enclosure so you can see the Klein bottle topology. Otherwise looks like a bottle with a loop handle.
sorry no scanner no cad i hope the attached photo is ok to depict what i was thinking.
depending on size could it not be turned into a mid horn or mid bass perhaps?
i keep thinking of it like a long back loaded horn
If you read Mr.Pass's artical, he folded the horn the way he did because of space constraints....
Now, If you could get a glass klein blown and make it into a 'Nautaloss' style enclosure, that would be a really funky aesthetic.
When I saw Hippy's 'Micro Klein', I sent him a pm asking for more details, quote:
the demensions are based off the ones in the pdf, except everything was devided by 3.2 which scaled it down for a 2.5" driver
He also said that the driver used had no details on the 2" drive unit he used other than it looked like a $20 Dayton.
Hi. I'm reopening this thread to ask about a klien Bottle enclosure I've seen on Thingiverse page to see if anyone has any ideas about it and how one might go about calculating/modeling this type of enclosure?
I'm thinking of printing one out to try with a decent 2" driver. But I've just found I have some TC9FD-18-08 on the shelf, so was wondering about scaling up this enclosure to try out. Any thoughts?
