Hi
i have a repaired kicker zx1000.1, i was pushing a kicker l7 15" when it burn, now is repaired but not have sound. the amp had the PS burned, i change the irf3205's, the 2 tip41c, one tip42c, all the SMD resistors of the irf's, i replace the drivers 2sd667 with 2sd400 and the 2sb647 with 2sa965,
The amp turn on, have the green light and the relay click sound, the sink dont put hot.
When i was repearing the amp, the amp had the red light, dont click sound i burned the new irfs, when i change the tip's and two diodes of the tips and the drivers, i solve the problem and amp turn on but dont have output.
Yes, the irf's has these values: (front view)
first leg: 4.44v
second leg: 12.2v
third leg: ground
but in the tip's the values are wrong
in the first tip41c i can't measure the values, only the third leg, it has -13.96v
the second tip41c has 12.6v in the first leg, dont have measure in the second and 11.97v in the third leg. the tip42c has 11.7v in the first leg, 11.97v in the second and 0.12v int he third leg. i also change the c120ph diodes, near to the tip's.
I am confused with the order, is tip41c-tip41c-tip42c? i dont write the order and i dont remember. other doubt, in the electronic shop, they sold me tip41a, i put these in the amp, they said me it is the same as tip41c, is correct? or here is the problem?
other doubt, the u1d smd diodes near to the inductor, i need to replace? that values should be?
first leg: 4.44v
second leg: 12.2v
third leg: ground
Measure the DC voltage on the TIP transistors again but this time, place the black meter probe on the negative speaker terminal.
Does the relay engage?
The values are the same, only change the first tip41a in the third leg measure -3.86v, the relay engage and disengage when turn on and of my sistem, its ok.
But i noticed something, in this test i dont use the sink, only the circuit table and the protection/power leds. and the irfs dont heated, only the tips are little warm i think is normal, but the irfs when i touch some of irfs i receive a little discharge, and by accident i touch the two mospec f30d40d on the other side of the PS and i receive a big discharge¡¡ i think everything is working but a nonsense thing is wrong.
what else i have to check?
When you measured the DC voltage on leg 1 of the power supply FETs, did ALL of them have ~4.4v?
The voltage on the center legs of the first two TIP transistors should be about -24v and +24. The voltage on the center leg of the third TIP transistor should be 15v.
Black probe on negative speaker terminal for all of the TIP transistor voltages.
i check the values, in the first and second tip, the center leg i have -13 and 14v but it isn't constant, i use digital multimeter.
and in the third tip the center leg has 12v.
but i noticed one thing, the 5th irf3205 has 4.4v inthe first leg and drop down to 0.01v, i think here is the problem, i check that and i notice what happen.
i replace one irf3205, now everyone of the irfs have 4.4-4.6v in the first leg, 12v in the center leg, and ground in the third leg. but the amp dont has output, the values of the tip's are the same like the last repply.
The points that have ±22v should be connected to the center legs of the TIP transistors. Do you have open traces between those points and the center legs of the TIP transistors?
i will to check that and notice what happen.
but i have a doubt?? one side of the u1d diodes are 22.6 and -22.6volts (near to the big coil), wich must be the values on the other side of the diodes?? can i read these values with a multimeter?
It's AC voltage on the end of the diodes without DC. If you have a true RMS meter with a wide bandwidth, you may be able to read it with a meter. It's not important here because you have DC on the diodes.
hi
the -22 and 22 volts on the diodes drives direct to the middle leg of the tips, but here is a problem, in the first tip i have -22v in the first leg but in the second tip i have only 12v, i check the values of the resistors(near the tips and around the caps) and its ok but i replace them. but the 22v not available only 12, i will to change again the diodes and the resistors, do you think here is the problem?? one side of the resistors has the -22 and 22v, but on the other side only one has the -22v and the other only12v.
On the TIP42, you should have -22 on the center leg. On the center TIP transistor (TIP41), you should have +22v on the center leg. On the third TIP41 (the one separated from the others and away from the power supply FETs), you should have approximately +15 on the center leg.
ok, i will check that because in my amp i have tip41c-tip41c-tip42c, and the correct order is tip42c,tip41c,tip41c, is ok?
- General Interest
- Car Audio
- Kicker zx1000.1 no sound¡
