thanks for the quick answer¡¡
but, There is another circuit I can use? because here is dificult to find this circuits and i cant find one with that part number
thanks¡
thanks¡
I know of no other drivers that would be the same. You'll have to order them if you can't get them locally.
I HAVE A KICKER ZX 1000.1 NO OUTPUT TURNS ON GREAT GOOD CLICK BUT NO OUTPUT WHAT SHOULD I LOOK AT FIRST??? PLEASE HELP😕
Take your caps lock off and keep it to this post and see what happens. Multiple posts not required.
Good luck.
Good luck.
i have looked at my zx 1000.1 turns on great but no output i have no scope so i cant drive power hat way is there another way???
If no one else can help, start a new thread and I'll try to help. I won't reply in a thread for a different repair.
I don't understand the statement about powering the amp and the scope.
hi, im back, i replace the ir4426 with tc4426, and the optos 2601 with the 6n137, i have all voltages ok, but the output fets are not working.
i put a wire betwen rca shield and amp ground, not sound.
about 110volts on the outputfets, so the PS is working fine
what i should to check??
i see in other post how to check the out pin in the preamp, i do this:
put a 100mhz signal with a player conected to the rca inputs,
turn on the amp relay engaged and checked is ok
check the volts in the gnd and out pins on the preamp
i have -0.47 volts on this pin, with and without signal, i know something is wrong, but i dont know who is or where start to check.
i check the voltage witch dc, not ac¡
now i check with ac and i have 0.01 to 0.70 volts in ac, but i change the gain pot because the other person who want to repair the amp stole me this pot, so i change with a common pot of 20k, i solder only 2 pins, the pins who change the oms from 0 to about 20k, so its ok but this pot is 20k or other value???
i check the voltages on the out pin again, i read from 0.5 to 6 volts, so i know is ok. now what i should to check??
Just make sure that you have rail-rail swing on at least one leg of each of the output transistors.
- General Interest
- Car Audio
- Kicker zx1000.1 no sound¡
