Kevin Gilmore
I'm trying to search for a quad transistor array with 2 x NPN and 2 x PNP but I'm drawing a complete blank.
Sorry for an OT but this is my new buddy, Hermes
Is it really necessary to use E96 resistors in this design ?
I have seen two boards that use different resistor values in the same positions.
50K could surely be 49.5K.
3K0 - I can't find them
5K0 - I can't find them
700R - I can't find them
Probably not. The "right" values are:
50k = 49k9
3k0 = 3k01
5k0 = 4k99
700R = 698R
Depending on where the resistors are located you can probably get away with a few percent off (value + tolerance). Because it is a differential circuit, in some places the matching between sides is probably a lot more important than the absolute value.
