Thanks guys. I've ordered some sticky back velcro hook so that should land on Wednesday.
I love this forum. I love how I can ask a question and get an answer without feeling like an idiot. I just wish I had the technical knowledge to really take advantage of the information here!
Yup [emoji4]
They need tarting up a bit and I've left the top loose so I can get the stuffing in.
I have no idea what I'm going to do for a finish, and I also need to put some little outriggers on or something for some adjustable spikey feet as my floor is seriously uneven.
Yup [emoji4]
No pictures it never happened
I took out the front stuffing sounded way better with it out rather than in, took a long run in but now these sound fantastic.
Ha. I'll take some pictures on Tuesday when I'm back at work. They look a bit naff at the moment to be honest.
I got a roll of sticky back Velcro hooks to put on the walls below the driver for easy stuffing adjustment. I'm going to test with max, half and no stuffing and see what difference it makes.
Third picture shows the rear section stuffed with only 40g of stuffing and not all the felt in yet but I've done that now.
Yeah - I've only put 2/3rds of it in as I hadn't stuck the rest of the felt in when I took the picture.On the back bit the fluff should come up to the top of the partition.
dave
Put some veneer on at last!
This must be the slowest moving build EVER.
Fronts and tops are veneered in Zebrano and will be clear coated. The rest will be in a glossy non metallic black. Hopefully whole thing will have a really glossy finish.What happened to the veneer?
Cool - look forward to pics once they're done.
Aluminium bar arrived today, from which I shall be making the outriggers to level them up on my wonky floor with! There are threaded steel inserts in the base of the speaker cabs that these shall bolt too. I'll get them anodised black along with the rear terminal plates. Can't wait to get the cabs back from the painters.
Well, you were wanting something pro...
looks like you've got it! I wish I had a cnc machine. For 10 bucks, is there a cnc plan? I'm sure I could find a company nearby.
Is anyone making decent binding posts without the bulkage....I've always thought the same as Dave yet haven't heard anyone else mention it. I try to avoid anything to do with cable reviews etc. I have used whole Cat 5 for speakers....may go down to 2 separate strands. Thanks for the suggestion Dave.
Thanks man [emoji5]
I really REALLY hope the guy painting them does a good job. I have built the cabs to a decent standard and they are dimensionally accurate to within a gnat's **** - I don't need someone messing them up for me now!
Already thinking of next project. Now I'm single [emoji17] , I can have a bedroom system [emoji1] , so thinking A7.3 bookshelf/stand mount jobby. Ooooh.
Simple binding posts that are light on metal:
https://www.parts-express.com/parts...y-speaker-wire-binding-post-terminal--260-302
https://www.parts-express.com/round-speaker-terminal-cup-2-7-8-gold-banana-binding-post--260-283
- Full Range
- KarlD's FH XL Alpair 10.3M Copper build
