"Jonokuchi" - new desktop amp, or "Little red board"?
I am really newbie with all tube related amp, sorry for my questions.
In the purpose to do an headphone amp only, does it make sense to get output transformer with lower power rating? 5W or even 2W? (In order to increase quality? bandwidth?)
It looks also that those tubes "13EM7" are not so easy to source, it is possible to use some alternative? Even if some values of the schematic must be changed.
Touister said:
How big is the PCB?
4.5 inches x 11 inches
Personally I used a 10W Edcor as shown in Pete Millett's design. I imagine a lower power xfmr would work adequately since it will be lightly loaded.
I got my 13EM7 from ebay, they range from $5 ea up to almost $20. I paid about $40 for a lot of 10 NOS tubes. I see you are in Germany, so maybe the shipping is cost prohibitive.
Optional Edcor Iron question was not answered ...
Back up in post #92
Some one asked the question about different Edcor OPT's and what would happen to the output power with different OPT's
I'm thinking of this amp to drive a set of Mini Karlsonators in a smallish room for listening to mostly blues. May add a sub woofer, but not sure.
So, I have a feeling a bit more output power may be need than the headphone version.
This amp seems a bit less intimating as a first tube build than the engineers amp.
Any comments?
Dave
You can certainly increase power a little by changing to an OPT with 3.5k or 5k primary impedance, instead of the 8k I used. You could get maybe 4W out instead of 2.5W.
Edcor GXSE10-8-5k, or GXSE10-8-3.5k would be the parts.
The distortion will go up a bit. For blues this might sound a bit muddy if you go too far. So I would go with 5k.
Pete
