John Curl's Blowtorch preamplifier part III
Well......it’s like this. In a flea bay type situation i’d be lucky to get $1200 for it.
It’s more principal at this point......I see a good product that was taken from behind in manufacturing.
If I lose the patient I will not cry, I have a better sounding unit in use so I will not be without sound. And to tell you the truth I’m comfortable that I can make these mods without screwing it up.......I might come off as a moron in my quest for information but I’m really not.
I appreciate everyone’s concern though :)
Here ya go
Bob,
You might think about some questions before starting:
What is the amp worth if you sell it now in working condition?
Are you willing to risk complete loss of the unit if things don't turn out well?
How much money are you willing to spend experimenting with it?
X2; and if you're going to solder things directly, find which connections might actually matter and do only that so you lose the least serviceability, e.g. output to binding posts.
Joined 2011
LH0033 hybrid as output stage of headphone amp
Although I had several LH0033s to play with, I didn't want to risk them in an unproven and not-bug-free amplifier board. So I decided to build an "emulator" daughter card, which plugged into the LH0033 socket and performed the same function, using low cost, easy to buy, active production components. If I destroyed a few of the emulator cards, so what. They're easily replaced.
Then the penny dropped. I realized that these LH0033 emulators were, in fact, interchangeable Output Stage Daughter Cards. I could swap new output stage designs in and out, as often as I liked. Perhaps to optimize measured performance, perhaps to optimize listening pleasure, perhaps to minimize parts cost, or perhaps to use up my stash of 1971 Linear Hybrid devices. Eureka.
Besides the LH0033 itself, here are some of the daughter cards I built to drop into the output stage socket. A couple of them use the "Objective 2 HPA" idea of parallel opamps with 1R5 balancing resistors; in my case, four parallel opamps, i.e. two duals. Then there's a BUF634A, an LME49600, and a discrete push pull buffer using 200 MHz VAS transistors in the TO126 package. And, perhaps, more to come.
_
Joined 2011
Daniel, it's a composite. However the LH0033 is only a unity gain buffer so it doesn't increase the loop gain. It does add a few degrees of phase shift at the unity gain frequency of the entire loop.
Here are the exhibit plaques that I placed next to the amplifier on display at Burning Amp. I think they probably tell you exactly what you want to know.
MJ
{I did exhibit another composite amplifier called "Rojo", with a total of ~180 dB of loop gain. An IC opamp in series with a high power discrete opamp. Yes it was fun to figure out how to compensate that unholy swamp. No it didn't use LH0033s.}
_
Please keep it as it is. The soldering points shown by Max in the first picture may be connected to the terminals with thin traces, can't see because they are on the flip side. To solder there if that is the case would make matters worse.
The other picture underscores Max's lack of insight. Of course, the Zobel does not have two resistors.
There is guaranteed nothing to be gained sonically from bypassing the PCB connector.
As they say, curiosity killed the cat amp.
Hey don’t worry about my feelings, I appreciate the point/counterpoint........helps one make more informed decisions.
You've been informed about the "fool's errand" relating to this attempt. It's now up to you to digest the info.
MJ
_
Ah very cool! Sounds like it was a fun and fulfilling project. Reminds me that I have a bin of rescued TDA7293's that I was going to build an unholy front end for and tap in for their outputs. Logical? No, but fun in its arbitrariness.
Pavel -- one gets the impression that using the LH0033 was more for the challenge and satisfaction of marrying "ancient" parts in a modern way than for the absolute best performance money could buy.
