That much EQ on the top end??
Shades of Bose 901s...
How do they keep the distortion low??
_-_-
_-_-
Have I stumbled on the secret society of M2 owners or does Richard assume we all have a pair? I thought he was alone on here in that.
_-_-
Bose EQ's the top and low because it's just a bunch of 3 or 4 inch drivers in the 901's.
You know that their other systems chop up the signal at a high frequency in order to make it sound like it's filling the room? At first the bass sounds big, but then you notice nothing is shaking or vibrating at all...
You don't own M2's? They are the standard around here... you can't be in on the discussion, clearly.
"No highs, no lows, that's Bose".Bose EQ's the top and low because it's just a bunch of 3 or 4 inch drivers in the 901's.
Dan.
I wouldn't really call that a horn. It's not of significant size at even the shortest wavelength of interest. Within the throat of a true horn discontinuities of impedance cause reflections, a classic issue with pro-sound designs.
All good fortune,
Chris
Most gave up on the Horn forumlas quite some time ago.... The work now is on wave guide theory. This M2 wave guide appears (my guess) to be designed first and formost to give constant directivity... let the FR fall where it may and correct the FR later with DSP.
I just did a quick check on the FR around the room with RTA using pink noise... close to speakers and far away and in between.... the narrow dispersion and flat power response works very well... the response doesnt change hardly at all in FR around the listening area.
because of this, I am also not hearing nearly as much room effects/coloration on the sound.... technical term is ... mush. Much clearer sound.
THx-RNMarsh
THx-RNMarsh
Much improved horns are possible now using iterative models and true (spherical section) wavefronts. Previous flat wavefront models were never even a decent approximation. Good info here on DIYaudio by looking at the work of Jean Michel LeCleac'h. My father did the same thing at the same time, way before the internet.
All good fortune,
Chris
All good fortune,
Chris
I still want someone to explain JBL'S old acoustic lenses... Never got those.
Marsh, do those M2's take batteries like the other JBL's?
Complicated by the fact that they're not "lenses" and the entering wavefront isn't flat.
All good fortune,
Chris
All good fortune,
Chris
It is quite safe to say they do not. Those were one designer's notion of polarizing back-to-back electrolytics, and despite demonstrably higher distortion that bipolar electrolytics he insisted that they sounded better.
The batteries in the speakers was a G. Timbers thing. M2 is not from the Timbers camp. As far as I can tell the M2 Started out as a Doug Button/Allan Devantier creation with Charles Sprinkle doing the final acoustic tuning.
I thought the purpose was on the tweeters capacitors, because it was suppose to make them sound a little nicer?
You guys should have seen Trainer's s*!t eating grin when first saw the battery on a speaker x-over board. Priceless!
Please, you're asking the most ridiculous thing. No, that's a question as if I couldn't even tell you what direction electrons flow.
Horns prevent the muddling of the music from interaction with the room. Non-horn speakers do not. So if the electronics don't put out a high quality distinct signal because they're low noise, then without horns you have muddled music getting muddled more.
It's not overly complicated. But I've found with a lot of treatment for noise within and before the electronics gives such more district sound that room-treatment and type of speakers becomes less of concern. It's still beneficial, but perhaps not necessary as some would say. Obviously speaker enclosure plays a big factor, since ones that vibrate a lot are just as bad for the music's definition.
Well you talked about electronic noise being different with horns. That's what I didn't understand.
I now understand you paddle back on that and now talk about a difference in directivity between horns and cone speakers, which is of course a no-brainer.
So you still confuse electronic noise with acoustics, reflections and room influence. The two have nothing to do with each other.
Acoustic issues cause linear distortions, electronics (assuming the amp has a flat freq response) cause non-linear distortions.
I just wish you would be clear in your posts and then stand by them.
Jan
CH says ferrites, even on the mains side, can destroy the sound - are you using iron core inductors? Be careful on this point. Further, maple cable lifters will reduce common mode coupling between the cables and the floor. Failure to do this causes broadband standing waves and that of course can also result in muddled sound from non horn speakers. Alternatively, you can just go for book shelf ones and hang the cables over the drapes.
More L8r 😉
Not seen evidence of these golden ears you speak of no.
Ok, but that isn´t an answer to my questions. Could you be so nice?
<snip>
Yes please. It is your claim so you should back it up.
See for example:
Blech, Yang; DVD-Audio versus SACD: Perceptual Discrimination of Digital Audio Coding Formats; AES Convention Paper No. 6086
The AES-Paper was based on their Diploma-Thesis at the University of Detmold (Hochschule fuer Musik Detmold).
110 participants did 145 tests (each consisting of 20 trials) with various music samples. 3 listeners got 17/18/20 successes.
- Member Areas
- The Lounge
