1 J-amp 2003 working..
Hi all,
I've got one JLH 2003 Esl version working (one minor mechanical bug to fix)
It'll take some days to complete the second amp
and it'll not leave my shack until all bugs are fixed. so no serious impressions for now except one:.
Hi all,
I made my first ever pcb layout today for the JLH 96 amplifier. I hope it is any good. Suggestions and comments are welcome.
Some notes:
R10 is off the pcb because this one gets hot.
The routes can be substantially bigger.
It isn't very neat.
Some Transistors have wrong device numbers.
But besides these points, would it work? 😕
Some notes:
It isn't very neat.
Hi LaZarus,
You may have to give us better/clearer overlay part number in order to make any sense out of it. In my experience the R10 just get a little warm, not hot to touch, what Iq are you setting it to?
I can not see where, how the R6 connect to signal ground.
Chris
P.S. What version of 1996 JLH are you referring to?
What is that R11 2k2?
Chris
I have used this schematic, the updated '96 version.
Is it better to use a ground plane on my pcb layout, which will be connected to a star ground on my chassis, or an other grounding topology?
Here is my revised pcb layout.
Maybe a bit more important than a ground plane....
May i suggest wider traces, you have plenty of space.
You will get lower series inductance and lower resistance....
Sonny
Sonny
Ok, above is my new pcb layout, with wider tracks, place for a bigger capacitor and some other changes.
Any suggestions are still welcome.
btw, the decoupling C's still have to be added.
cheers
cheers
LaZarus said:Ok, above is my new pcb layout, with wider tracks, place for a bigger capacitor and some other changes.
cheers
Depending on your grounding scheme. The way I would do it IMO is to group the signal grounds(R2,C2,R6) and group the dirty grounds(R11,R12,C6,C7) separately. Each group then join to the star ground.
Chris
Feedback pick up point
LaZarus,
If you can consider R8 pick up point between Q2E Q1C and Output may be prefered to R8 pick up before Q2EQ1C as show in the schematic.
Chris
LaZarus,
Chris
Chris,
Thank you for your comments. About your previous post, can you please specify why I should place it behind Q1 and Q2?
I wil have to get a good look at it later this week, but can you please exlain what the theory is?
I have another question about the VA ratings of x-former. Nexus you run it from 2 120 VA transformers, but I also read about 450 VA's, which would be a bit expensive for me. I am planning to build this amp on a tight budget, just because I have to 🙁
Cheers.
Cheers.
Hello,
I use 2 transformers of 2x12VAC-120VA, this is 5A per coil.
I bias my amp with 1.2 to 1.5 A, this means approximately 8 Watts in audio power, so in this case there is no need for a higher rated transformer.
So the power rating of the used transformer simply depends on the amount of output power you want out of your amplifier.
Best Regards.
P.S.
I use a margin factor of 2, if 1.5A constant current is needed, the transformer has to deliver min. 3A constant.
for instance:
2x12V*1.5A=36VA used, margin factor min. 2: 72VA. So 120VA is more than enough.
Greetings.
for instance:
Greetings.
LaZarus said:Chris,
Cheers.
Please check section(5.6 DISTORTION 6: Induction from supply rails) at Douglas Self's web site
http://www.dself.dsl.pipex.com/ampins/dipa/dipa.htm#4
That was the experiment I tried with my JLH with positive result.
Chris
PS: of course I take it for granted that I trust Doug Self is right in the first place because I have no EE background. Many experienced EE/diyer don't trust or question what others telling them thingies. So you are on your own to decide and filter thru vast amount of information in this world. May the force be with you that is only if you believe in the force in the first place. Yeah why people say God bless you to other people that they do not even know whether they believe in God or the same God?
Self's Distortion 6
Since the JLH amp we're talking about is a
Class A design, the "halfwave-rectified
currents" that Self is concerned about don't
come into play. (That was a distortion peculiar
to the class B output stage.)
Therefore the feedback pickup point isn't as
critical.
eL
critical.
eL
Re: Self's Distortion 6
Could that be I have made mistakes wiring up my JLH so that it may not be actually running in Class A mode? For sure to me anyway the mod of the feedback pick off point in my amps produced even darker background and overall clarity to the sound.
Chris
eLarson said:Since the JLH amp we're talking about is a
critical.
eL
Chris
Chris,
I couldn't begin to speculate. Perhaps the new connection is more solid than the last, too. Hard to say. I certainly wouldn't change it back if I were you. 🙂
Best,
Erik
Best,
Erik
JLH feedback take-off point
Chris,
When I reconnected the feedback take-off point in my circuit in line with Doug Self's recommendations, the result was a similar improvement to what you have described. I found it surprising at the time, so much so that it made me think of the pros and cons of extending the take-off point to the terminals on the speakers! I suppose this demonstrates the the sensitivity of the n.f.b. loop.
Tim.
Chris,
Tim.
Hi Lazarus,Originally posted by LaZarus I have another question about the VA ratings of x-former. Nexus you run it from 2 120 VA transformers, but I also read about 450 VA's, which would be a bit expensive for me. I am planning to build this amp on a tight budget, just because I have to 🙁
Cheers.
I run my 1996 version rail of 22V @ 1.9A bias from a 225VA toriod for each channel.
I'm now building the 2003 version (28.5V rail @ 2.8A bias) and use a 330VA toriod for each version.
One is finished
A suggestion is to buy one "big" toriod now and run both channels for the time being from this one. You can upgrade later.
28,5V
...why 28,5 Volts at 2,8 amps?
has anyone made (sound)-experiences about the enhanced power supply and quiscent current?
Ralf
Ralf
- JLH 10 Watt class A amplifier
