jupiterjune said:Magura-
Of course, you know the correct answer was 6 ohms?
Woodie-
The CCS is on the lower rail feeding the sources of the input fets. I have never tried using a CCS as a load. Or an inductor, for that matter -- but I hope to try the 'choke loaded' version soon.
Neat thread!
JJ
Cool.....I'm glad you you're having fun.
I'm having fun, but I'm also learning to laugh at myself...growing pains at my age, sheesh...
The neat thing is I learn a truck-load when I put-it-on-the-line.😀
JJ
Today, yes 🙂
Back 4 years ago, not really 😉
Magura 🙂
Magura said:
Today, yes 🙂
Magura 🙂
Did you ever try the zobel filter? I wonder if it makes a difference? The amplifier would probably be happier...
Yeah, isn't it nice to see so many happy people? 😀
Magura 😉
I never had a need for such, so I can't comment on this.
Magura 🙂
carpenter said:Did you ever try the zobel filter? I wonder if it makes a difference? The amplifier would probably be happier...
Not always, but there are many examples of subtle (or even
not so subtle improvements to be had by RC networks in
parallel with the load.
The trick is usually values and placement.
Nelson Pass said:
Not always, but....
With all the irregularities that an amplifier must overcome, I had the thought that an amplifier might perform better with an even load impedance--one less obstacle.
Thanks for your thoughts, Nelson.🙂
BTW, If you happen to catch this, would you care to comment on the difference between choke loading a power amplifier vs. a pre-amplifier? It seems that a pre-amplifier requires a choke with greater inductance.
say that you choose resistor as load for your tiny jfet stage
say that that resistor is ........ 5K
say that you're nutz and wanna use choke instead
say that choke have decreasing impedance with frequency
say that you wanna decent bass
say that you choose 20Hz as corner for your decent bass
say that you think that is nice to have choke -acting as 5K resistor, even on 20Hz
say that you gonna abuse and molest google, chasing....what else than choke -having 5K impedance at 20 Hz
say that internet is full with places where you can find nice xls for calculating how much H you need for 5K at 20 Hz , even if ya don't know that simple it is : L= Z/(2 x Pi x F) ........so - 5K/(2Pix20)=39H
say that I didn't wrote anything ......... and that you conclude it by your self
Zen Mod said:...say that you're nutz and wanna use choke instead...
=39H
I see nothing bad written there...
carpenter said:OK, smarty pants, which one of you scholars wants to go first? I haven't a clue how induction at 20k hz is calculated.
Edit: Nelson mentions using a 1H coil of wire, so I thought this might be a good place to start.
I've noticed that 125mH works and that 4H works. Which is best? I don't know.......
Darn, I guess I'm not first
It is not just the imeadance of the inductor at the -3db point that we need to be concerned with. When I was working on the choke loaded ZV9 idea and testing with square waves I had a "tilt" to the square tops of the wave. This was due to my 120mH choke load and it can be caused by capacitance also. Hmmm... Whenever you try to use a cap or an inductor you are going to experience phase shift
Just like in a capacitance caused rolloff, if the -3db point is 20Hz, there are still capacitance effects happening as much as 3-4 octives higher (160-320Hz). This is why you commonly see coupling cap values set for about 2.5Hz -3db point. 3 octives higher is still only 20Hz. So the phase shift and other capacitance non linearities and whatnot, are just begining to effect the sound at the very bottom of the required passband and below.
Bigger(to a point) is better in this case. A Henry is a pretty big thing if you want output current levels through it. Nelson's 1H is 10 times the value I was working with in the inductor loaded ZV9 idea. Henry's are a much more managable value if your only working with a few milliamps 😀
Zen Mod said:say that you choose ....
flg said:
Darn, I guess I'm not first....
Excellent information, guys. Choky, I've been playing around with the xls inductance program--what an education that's turning out to be. These ideas seem somewhat hidden in my mind and it's refreshing to pull them forward for examination.
My little F4 is a treble amp, so this explains why I've been getting away with various inductor sizes and not noticing a variance. I'm planning to operate the amp without an electronic x-over, run bass sine waves, and put it on the 'scope.
As always, many thanks. Guys like me need guys like you.....😀
Thanks, but I really could have been much more explanitory towards the phase shift biz. I'm not sure I can... I'm not Nelsoncarpenter said:...Excellent information, guys...
carpenter said:...My little F4 is a treble amp, so this explains why I've been getting away with various inductor sizes and not noticing a variance. I'm planning to operate the amp without an electronic x-over, run bass sine waves, and put it on the 'scope... 😀
Well, square waves rely on a sine wave fundamental and sucsessively smaller level odd harmonics, in phase, all added together. They all add to be a square wave. With phase shifting from the inductive or capacitive component, the square will be distorted into something not square. Ussually a tilted looking thing...
You need to design in these components to be a very small portion of the voltage drop, or developing voltage component if it's in the signal path...
If the amp never sees the lower frequency, why does it have to be designed to give a good square wave that relies on lower frequency harmonics? I'll just skip the square wave test if that's the case.
Doesn't that depend on the frequency of the square wave? I think you need to just be sure that you don't have distortion in the frequency band you are using. So test within the range being used. In those frequencies the square wave test should be relevant.
DaveM said:Doesn't that depend on the frequency of the square wave? I think you need to just be sure that you don't have distortion in the frequency band you are using. So test within the range being used. In those frequencies the square wave test should be relevant.
I would hope so; I'll certainly try it out.
Right 😀
If you have a big enough cap or inductor, the square wave test should show something close to "square waves" in the frequency of interest. If designed for lower frequency, you might say you are wasting money(these components are $$$), or space(good Caps and most inductors are big. But, when Xc is at a level where signal can be measured across the cap, (Inductors are ussually the oposite function I think) they may also be contibuting to unwanted distortion and phase...
That may be so, but to my ear, there's not much difference in sonics between a 150mH leg and a 4mH leg above 500hz--regardless of the square wave. But, then again, I'm not the golden ears of the family. 😀
Unless I'm feeling anal, and that's generally a temporary condition. 😀
That is, unless I'm getting paid by a customer for remodeling his house, of course!
carpenter said:That may be so, but to my ear, there's not much difference in sonics between a 150mH leg and a 4mH leg above 500hz--regardless of the square wave. But, then again, I'm not the golden ears of the family. 😀
That is, unless I'm getting paid by a customer for remodeling his house, of course!![]()
80mH * 2 inductors does the trick for feeding a FE166e. If you feel you have a need to go deeper than approx 40hz, you may need more, but I have not seen any need for this for full range drivers anyway.
Magura 🙂
Have you run a sine/square wave test to determine the accuracy of the amplifier?
I like the sounds of 80mH per leg.😀
carpenter said:Have you run a sine/square wave test to determine the accuracy of the amplifier?
The square looks pretty ok till 50Hz, the sine looks fine as well.
To my ears, it offers just about anything I've ever wanted.
Magura 🙂
- JfetBOZ mods
